001Ben
| posted on 17/8/08 at 12:12 PM |
R1 Fuel Pump Wiring
I have wired up all of the electrics for my 2001 R1 engine, I have turned the ignition to put power onto everything ( clocks, bike loom fuses etc) but
havent heard the fuel pump prime. Does this only prime when the car is actually starting or will it be waiting for something else i.e side stand
switch?
Hope this makes sense
adithorp
| posted on 17/8/08 at 12:27 PM |
Pretty sure it should prime when the ignition goes on. Mine's an 06 though.
adrian
http://jpsc.org.uk/forum/
mackei23b
| posted on 17/8/08 at 01:20 PM |
I've got a ZX9R and the fuel pump will only run either when cranking the engine, or when the engine is running.
The relay on the pump is set this way so that the pump does not continue to run of the engine stalls, but don't know about the R1.
Try disconecting the starter motor main cable and then use the ignition key and listen to see if the pump starts to click.
Ian
mad-butcher
| posted on 17/8/08 at 01:57 PM |
pump should run for about 5 secs then shut down until you crank it and it starts running, pain in the arse when your trying to prime the carbs, fooled
me till i posted similar question
Tony
