macspeedy
posted on 25/8/08 at 09:06 PM |
ZX12 imobiliser question
Hi we are doing the wiring at the mo and remember that you have to do something with the imobiliser, what is it? and are there any other tweaks
needed.
Graham
imp paul
| posted on 25/8/08 at 09:52 PM |
if you have the ignition barrel you will be fine if not you need to put a resistor in as this is the immobilizer hope this helps and also the stand
switch needs to be sorted good luck paul
[Edited on 25/8/08 by imp paul]
| posted on 26/8/08 at 05:32 AM |
Basically what Paul says. The barrel has a 100 ohm resistor parked in the bottom of the moulding. If you still have the barrel, either wire it in our
put a replacement in series.
