welderman
posted on 9/1/12 at 11:54 PM |
quote: Originally posted by bigfoot4616
quote: Originally posted by welderman
I hate wiring
you'll have quite a bit to do on yours won't you
Yes I will. Not looking forward to it one little bit
Thank's, Joe
I don't stalk people
posted on 10/1/12 at 12:46 PM |
New plugs.....
Phil
bigfoot4616
posted on 10/1/12 at 07:09 PM |
went to get some new plugs today, they didn't have any so will try and get some tomorrow.
phoned up malc today as he supplied everything and he suggested some fuel in the throttle bodies to see if it would spit back through them, if so coil
wires would need swapping round.
made no difference.
had a good look over the wiring and noticed that on the multi plug that connects the coils to the main loom the coil trigger wires didn't match
up with the same colours either side of the plug. i then swapped the coil connecters round so they where correct with the ecu side of the loom, ended
up swapping 1 and 4, 2 and 3.
still didn't start but this time it was puffing balls of flame out of the exhaust ports.
with tonight's previous attempts to start it there was quite a bit of petrol about which had got soaked into a rag i had left on the floor,
when it first flamed it ended up with me having to stamp on the rag a few times to put it out
another call to malc tomorrow i think
bigfoot4616
posted on 11/1/12 at 06:45 PM |
new plugs are coming friday, no one local has any in stock.
put the coil wires back to there original location. then i gave the plugs a blast with a blow lamp and it nearly started, if i hadn't stupidly
let go of the start button i think it may even of started. needed to get back to work so left it at that. will try again tomorrow
welderman
posted on 16/1/12 at 04:52 PM |
any news fella
Thank's, Joe
bigfoot4616
posted on 16/1/12 at 07:30 PM |
still not running. not really any better with new plugs although it now will nearly start with a little fuel poured down the throttle bodies but not
when the injectors are squirting.
spoke to andy bates today about something else so i asked him, he thought that everything sensor /switch wise must be correct as its trying to go with
fuel and spark. i mentioned it was a white spark and he reckoned it should be a "fat blue" spark and possibly a weak spark could be
stopping it starting. suggested checking it had good engine earth.
it was very cold in the garage at the weekend which wont have helped, also meant i didn't spend much time in there
welderman
posted on 16/1/12 at 07:59 PM |
I'm not the best with electricity but if you need an extra pair of hands I will pop up if your desperater
Thank's, Joe
Davg
posted on 16/1/12 at 08:17 PM |
If you are in doubt about the wiring and its not hard wired to the car yet, If you want to send the loom etc up to me I will get the lecky part of it
checked against the cars that I have here an get it runnining on mine.
No doubt you are getting severly pee'd off by now!
(done 3 5vys & got 2 cars here)
What is your set up at the mo ECU & loom, uk or states?
cheers D
bigfoot4616
posted on 16/1/12 at 10:22 PM |
thanks for the offer joe but got a few things to try, hopefully tomorrow night if it is a little warmer in the garage and then i'll be giving
malc another ring if still no joy.
cheers D
again thanks for the offer but i'm sure i'll be able to get to the bottom of it soon, there's only so much it can be.
its not bothering me to much at the moment as i have plenty of other things to get on with so itsw not really holding me up.
not sure what the loom is, the ecu has 20 on it. both supplied by malc along with the engine
matt_gsxr
posted on 16/1/12 at 11:02 PM |
Have you connected up the throttle cable? Looking at the video it looks like there isn't one.
Maybe your engine can start without a timely blip, but on occasions I have found it useful to blip the throttle (either the help the engine spin a bit
faster, or to clear a bit of a flood). You might also want to connect a substantial (maybe car) battery as those little bike ones are a bit rubbish
(especially when cold).
bigfoot4616
posted on 16/1/12 at 11:20 PM |
no throttle cable connected, i have been playing around with the throttle direct on the throttle bodies but it doesn't make any difference.
lack of 3 hands meant i couldn't do it while videoing
to get it to where it nearly starts on fuel dribbled direct into the throttle bodies i also have to open up the throttle.
soon gave up with the bike battery and am using a good car battery at the moment
Davg
posted on 16/1/12 at 11:57 PM |
No worries, these engines will start up no problem if the set up is right without fannying about with throttle cables etc!
Offer is there if I can help.
cheers
D
bigfoot4616
posted on 11/2/12 at 10:01 PM |
it runs
malc had sent me various things to swop over and try including another ecu. nothing made any difference apart from the start cut of relay when it was
much closer to starting. from the diagram i can't see how that can of been causing the problem though.
back in the garage today managed to get it to start by disconnecting the linkage to the secondary butterflies and manually opening them and holding
the throttle wide open when cranking, after about 20 seconds it fired up and idled ok.
no exhaust so i only ran it for 30 seconds. 20 minutes later tried it again and it started on the button with no throttle.
hoping it gets a bit warmer next week so i can get cracking on the rest of the jobs that need doing.
thanks
welderman
posted on 11/2/12 at 10:12 PM |
Nice one. You can come wire mine up now lol
Thank's, Joe
adithorp
posted on 11/2/12 at 10:49 PM |
Nice one.
http://jpsc.org.uk/forum/
bigfoot4616
posted on 17/2/12 at 11:12 PM |
hows it coming along?
welderman
posted on 18/2/12 at 12:36 AM |
Slowly. Sorted fuel tank out. Sent my engine to AB. My gear box is knackered
So gone even slower
Thank's, Joe
