PorkChop
posted on 18/5/16 at 05:06 PM |
Have you thought about what diff ratio you need?
MX-5 ones tend to be on the short side for a BEC.
colimp66
posted on 18/5/16 at 05:43 PM |
The standard ratio of the MX-5 will be used initially as that's what I have. It has been mentioned that it may be a tad low geared and top out
at around 100MPH... My thoughts are that a 100MPH in an Imp will be more than enough and the acceleration should be brisk to say the least. It will be
a weekend toy at best and built for a bit of fun.
If I don't like it once finished it can either be modified again or sold on. It's a hobby and happy to keep messing about with it to get
it right or as good as I can.
Col.
colimp66
posted on 16/6/16 at 09:34 AM |
Started on the fabrication of the engine cradle for fitting between the two chassis rails of the Imp.
At the moment it is being supported by a temporary engine cradle below it sitting on a we trolley. This is allowing for around 6 inches of ground
clearance which may change slightly once the engine weight is taken up by the springs etc but hoping for it not to go much lower.
Hoping to get more done later this week.
Col
ali f27
posted on 16/6/16 at 09:49 AM |
Its all about mounting blackbird engine as crankcase distorts nipping crank speak to andy bates he might be able to help mount it properly nothing
wrong with engine just how its mounted
colimp66
posted on 17/6/16 at 09:27 AM |
Cheers Ali,
I have spoken to Andy regarding the Blackbird motor and he did mention the flexing issue that occurs with these motors often being the cause of
problems.
A bit more of the frame tacked in last night.
Col.
ali f27
posted on 17/6/16 at 09:35 AM |
There are 1000s of blackbird bikes with very big mileages so nothing wrong with motor and at the end of the day its a Honda will make a very nice car
good luck with it .
johnnybizzle1986
posted on 17/6/16 at 11:59 AM |
I have recently done a zzr1200 with a freelander diff 3.20 ratio worked really well.
regards Jon
colimp66
posted on 18/6/16 at 08:40 AM |
Cheers John,
Be good to see your conversion. Possibly bettered geared than I will be with using the MX-5 diff.
Made up the lower spars for the cradle last night all tacked in and feeling chuffed with myself on the look of the cradle.
Col.
Andybarbet
posted on 18/6/16 at 05:07 PM |
Looking good :-)
We just rolled my son's imp out & fitted some 13 x 8 alleycat wheels that he got 2nd hand, just needs a lot of shell welding unfortunately
colimp66
posted on 17/11/16 at 10:04 AM |
13x8's will just squeeze in under the arches I believe, I have 7's on mine at mo with 185/60x13 tyres but looking for a lower profile to
fit on the front to allow full lock without rub on the inner arches.
Been busy with a few other jobs this past wee whilst since I posted last. New dashbaord constructed and covered..This is it loosely fitted into the
car
This week it has been a bit of a tidy up where the engine pokes into the parcel shelf so I have mad e a cover/access panel for this. Reused the
original panel I had cut out but in reverse so it will cover the airfiler etc without touching.
Finally picked up my very short propshaft s I can get on with finishing of the framework to hold the engine and the diff combined which will then
allow me to have the driveshafts fabricated.
Col.
[Edited on 17/11/16 by colimp66]
colimp66
posted on 17/11/16 at 10:37 PM |
Now onto the engine and diff bit not in the car..... Yet!!!
Col
colimp66
posted on 6/12/20 at 08:31 PM |
Overdue update
Wow!! 4 years has passed since I was last on here, apologies for taking so long to give an update on my Imp.
So I have made the rest of the framework to take the MX-5 differential, propshaft was also made and the driveshafts adapted so the MX-5 ones fit the
Imp uj's to drive the wheels forward.
The car has been painted and a headlining installed, brake lines have been fashioned and fitted along with a clutch and fuel line too. Seats, windows
are fitted, sound insulation and some of the carpet as well as the engine being out back together and started up.
I've not been idle ... just slow at getting all of it done and upto date on here. Life and work getting in the way really and erm.. a pandemic
as well.
I'm now trying to figure out how I post some photos of the progress????
Col.
colimp66
posted on 8/2/21 at 10:09 AM |
[youtube]https://www.youtube.com/watch?v=3TQwP2EenmQ[/youtube]
Gearshifter made up.
[youtube]https://www.youtube.com/watch?v=nKmCFPoQq3E[/youtube]
Col.
