rjbrookes
posted on 17/8/06 at 03:20 PM |
that's the one
road test in a min.....weather drying up....
russ
rjbrookes
posted on 17/8/06 at 05:07 PM |
been out for a test drive and seems ok, couldn't drive it hard cos it was rush hour(s), but i was stilling in traffic for a while, water temp
never got above half way.......hopefully have a better run next once back from work....
Russ
G.Man
posted on 17/8/06 at 08:29 PM |
Sweet, ordered one
Opinions are like backsides..
marc n
posted on 18/8/06 at 07:48 AM |
good stuff just need some decent weather now to have some fun
we are testing at oulton on tuesday looks like we might get a bit wet
please email rather than u2u
chrismnrltd@btinternet.com
rjbrookes
posted on 18/8/06 at 07:52 AM |
dam i have to work.....otherwise i would happily offer my testing skills!
russ
G.Man
posted on 30/8/06 at 08:08 PM |
Bah, fitted 21-25 lever rad cap today, fired it up and it boiled over within 5 minute of idling...
posted on 30/8/06 at 08:32 PM |
Mark, have you got water wetter in with your coolant?
Phil
G.Man
posted on 30/8/06 at 08:36 PM |
Phil
yup
rjbrookes
posted on 30/8/06 at 08:51 PM |
i also have the MNR front grill removed, i noticed this helped in the heat at the Nurburgring in July, its stayed off ever since.....
Russ
posted on 30/8/06 at 08:58 PM |
It is rather warm though in Cyprus at this time of year. 42 degrees in Protaras last week
Other areas to explore;
Cut vents in bonnet/side panels.
Seal off area around rad so all air is ducted through.
Shield rad from engine so it doesn't get cooked by warm air coming through.
Spend a small fortune on some more water wetter and replace your entire coolant with the stuff.
Leave it in the garage until the weather cools down a bit
Phil
G.Man
posted on 31/8/06 at 03:42 AM |
Guys, this was done last night, idling in a cool 23 degrees... in my garage...
with the bonnet off...
Gonna do some more investigation, drain, refil and re-bleed the cooling system..
Change the clutch at the same time, and maybe see if I can mount the new pace rad, for extra coolant capacity...
I have plenty of water wetter, but all water wetter does it break down the surface tension on the water so you dont get boiling in the block/head...
its not as good a coolant as water..
