tks
| posted on 27/10/05 at 07:47 PM |
nope
i used an V4 the VFR 800 '98 injection.
hope google will still do the trick..
wy? they came with the rims (TWS IMOLA) and are brandly new i could pull the samll pieces of wire of them..
Tks
ChrisGamlin
| posted on 27/10/05 at 08:10 PM |
Ah sorry, knew it was a V4 but got the wrong one!
The reason I ask about tyres is that on such a light car, low profile tyres can really hurt the handling, big wheels for show, small wheels for go
[Edited on 27/10/05 by ChrisGamlin]
tks
| posted on 27/10/05 at 08:40 PM |
Got them!!
Primary reduction 1.939 (64/33)
Gear ratios 1 2.846 (37/13)
Gear ratios 2 2.062 (33/16)
Gear ratios 3 1.578 (30/19)
Gear ratios 4 1.291 (31/24)
Gear ratios 5 1.111 (30/27)
Gear ratios 6 0.965 (28/29)
Final reduction 2.687 (43/16)
Dunno if they are through.. but if they are right..i will deffo need another diff....
Tks
3.6 will be the way to go.. the only bad news is that i have remounted one mounting for my diff on my Velocity XT...
7inch?7,5inch diff?
G.Man
| posted on 27/10/05 at 08:55 PM |
3.38 from a sierra diesel and space the diff
Opinions are like backsides..
tks
| posted on 27/10/05 at 09:07 PM |
mhhh...
I think i can be lucky that i have an bike with overdrive in the box...
Think its time for 55 tyres and an 3,62 diff....
In this setup it tops out at 168Km/h hitting the limiter in top gear!
but at cruising (would be main goal for me, daily use)
i need 8400Rpm for 120Km/h max speed here.. think the fuel consumption will be high at that engine speed.
If i fit 55 tyres and an 3,62 diff.
It will top out at an nice 195km/h (hitting rev limit)
And 7200rpm for cruise speed (120Km/h)
Can anyone confirm this?
if this looks to much for my engine (782cc) then maybe 3,62 and 50will be the combo.. 189Km/h hitting limiter and 7500rpm for 120km/h....
What tyres do we use over here???
Chris??
ChrisGamlin
| posted on 27/10/05 at 09:22 PM |
If you download the spreadsheet I use from here, just edit it for the figures you have for
your engine and tyres etc, and it should give you a good idea.
Chris
