welderman
| posted on 19/3/07 at 10:57 AM |
Regulator help
Can you peeps running turbos complete the arrows please, going to add another outlet to my plenum chamber tonight so this is the next step forward.
Joe
Thank's, Joe
I don't stalk people
dilley
| posted on 19/3/07 at 04:13 PM |
Left: fuel in
Bottom: fuel return to tank
Top right: feed from plenum
Bottom right: fuel out to carbs
welderman
| posted on 19/3/07 at 04:21 PM |
Nice one dilley, your a gent.
Thank's, Joe
dilley
| posted on 19/3/07 at 04:24 PM |
No probs! just make sure its ready for York
welderman
| posted on 19/3/07 at 06:54 PM |
thats if its blooooming ready, eat, live, sleep, work at the min.
Thank's, Joe
welderman
| posted on 18/6/07 at 03:05 PM |
worX picture, if you want more just ask.
Joe
Thank's, Joe
welderman
| posted on 18/6/07 at 03:10 PM |
another
Thank's, Joe
welderman
| posted on 8/8/07 at 06:22 AM |
Finnally collected the car from, Malc at MB and im very happy with the results, i cant put a figure on what Malc has done on the turbo side as his
bill came with the added parts i needed for the clutch and gear box etc which had been abused , just need to fit some bits of body work i removed
prior to Malc doing his work. Will keep posting as i get some use out of it.
Thank's, Joe
zxrlocost
| posted on 8/8/07 at 08:07 AM |
so what kind of performance results are you hoping to get?
welderman
| posted on 8/8/07 at 09:01 AM |
looking at approx 180 at the wheels, took it for a spin round the block, phenominal.
Thats a big work for me
Thank's, Joe
welderman
| posted on 21/11/07 at 04:03 PM |
not been updated for a while.
Firstly the car is running lean at the mo so that needs sorting out, but since i started the build, ive also got some new Hi-spec brakes, some team
dymamic 15" wheels and R888's .
Not to mention a daAvies craigggg booster water pump. Plus some other sundry bits too.
Thank's, Joe
Kriss
| posted on 21/11/07 at 04:27 PM |
very intresting build. Best of luck with it all.
Are bike lumps converted to turbo common, esp on the 'Blade?
welderman
| posted on 2/12/07 at 11:41 AM |
charge cooler rad in nose cone
Thank's, Joe
richard thomas
| posted on 2/12/07 at 03:31 PM |
I love that manifold...gonna have to do something similar due to clearance issues. Question though, have you noticed any lag due to the length of the
primaries to the turbo?
welderman
| posted on 2/12/07 at 05:16 PM |
not noticed any lag at all, i might do when i fit the charge cooler, but im told that as the engine is in a higher rev range under boost that it will
be very minimal.
Thank's, Joe
richard thomas
| posted on 2/12/07 at 05:20 PM |
That'll do for me
welderman
| posted on 2/12/07 at 10:56 PM |
made your mind up then, did'nt take much!
Thank's, Joe
