IDONTBELEIVEIT
posted on 16/11/08 at 06:53 PM |
Ht leads Which Order 893 blade
i know that 1 and 4 go to the same coil and 2 and 3 go to the other,but does it matter which one on the same coil goes to which,ie swapping 1 and 4
over does this make a difference
help muchly appreciated
![](/images//smilies/sad.gif)
Are We There Yet, Are We There Yet!!!!
IDONTBELEIVEIT
posted on 16/11/08 at 06:59 PM |
any ideas??
posted on 16/11/08 at 07:34 PM |
Is that a general question or are you not sure which coil goes to which cylinder? If it's the latter, according to the manual, Black/White goes
to No1, Yellow/Blue to No4 on one coil pack. On the second coil pack Black/White goes to No2 and Blue/Yellow goes to No3.
HTH
Phil
IDONTBELEIVEIT
posted on 16/11/08 at 07:39 PM |
cheers hellfire,just out of curiousity would it matter??cheers wayne
mark chandler
posted on 16/11/08 at 07:43 PM |
Its a wasted spark system, fires both plugs together so make no difference.
Regards Mark
posted on 16/11/08 at 08:06 PM |
Firing order is 1-2-4-3
Fitting leads the opposite way round would give a firing order of 4-3-1-2, which in sequence is the same order as above, so no difference.
Phil
IDONTBELEIVEIT
posted on 16/11/08 at 08:20 PM |
cheers fellas
![](/galpreviews/a838768-hyper.gif) ![Rescued attachment hyper.gif](/gallery/a838768-hyper.gif) Rescued attachment hyper.gif
