A1
| posted on 20/11/08 at 01:00 AM |
steamy radiator...
my radiators started steaming once the engines warmed up, it should be sealed, its brand new, so theres no real reason for it...i tested it up to
about 1.5 bar (very roughly) and there was only the slightest sound of air escaping...would it be okay to use it on this or will any extra pressure
make it go bang?
blakep82
| posted on 20/11/08 at 01:07 AM |
well, it'll boil dry eventually at the very least...
where did you buy it from? send it back!
[Edited on 20/11/08 by blakep82]
________________________
A1
| posted on 20/11/08 at 01:18 AM |
its not too bad though, just a wee bit of steam...
it only started happening after a wee incident where the water pump breather pipe came off and emptied the contents of the system everywhere, just
after i gave the throttle a wee blip and turned ot off...there was quite a bit from the radiator too...it was after that i tested it...
mad-butcher
| posted on 20/11/08 at 08:16 AM |
Is it actualy leaking or just drying the water off the outside of the core after the spill
Mr Whippy
| posted on 20/11/08 at 08:22 AM |
Radiators do tend to steam a bit after being drenched and then drying off…
| posted on 20/11/08 at 08:54 AM |
Not adviseable to test at over 1.2 bar
Leaks show up more when antifreze is added to the coolant (because it reduces the surface tension).
Only certain way to locate a leak is to pressure test filled with coolant when cold,
The test has to be done when cold because hot water under pressure flashes off into steam which is is invisible.
However on modern alloy/plastic rads the only way to repairl a leak is to use epoxy.
The other way to stop a leak is to add K-Seal (NB K-Seal don't under any circumstances use Bars Leaks or Radweld)
Mr Whippy
| posted on 20/11/08 at 09:41 AM |
I have Radweld in all my water cooled cars plus the digger and have done so for well over 10 years, never had a leak or any issues what so ever with
the stuff and also recently fixed Miss Whippys little corsa with it too.
great product
mad-butcher
| posted on 20/11/08 at 10:57 AM |
Now I'm curious I've always used radweld never had a prob. Pray tell me what's up with the stuff
dubstar_04
| posted on 20/11/08 at 12:04 PM |
I put radweld on my weetabix. I love it!!
RK
| posted on 20/11/08 at 02:08 PM |
Mine spews out the cap. Does this mean my cap needs replacing, or is there something else? It did it with no antifreeze and does it now with 50%
antifreeze. Brown crap coming out as soon as the engine gets warm. Course, I haven't tried it since I put the fan on. Ideas??
| posted on 20/11/08 at 03:06 PM |
great product
Barrs Leaks and Radweld istr are mainly Ferrous Shulphate based which was fine in the old days when engines and radiators had large bore waterways and
no thermostat.
Read the fine print warning on the Bars Leaks container --- it is death to modern engines with fine water passage ways such as Honda engines. More
than a few Honda V6 engines have been knackered by it.
Radweld which is much finer isn't anything like as bad but it causes thermostats to stick and sludges up the water ways.--- thankfully usually
open.
K-Seal is a totally different ball game more suitable for modern engines.
[Edited on 20/11/08 by britishtrident]
| posted on 20/11/08 at 03:10 PM |
Sounds like an airlock but it could be local overheating --- drill a couple of small holes in the thermostat to help it bleed --- of course you
should also have a by-pass hose running back from the thermostat housing to the water pump.
