Author: Subject: 'Busa Throttle Cable Return Spring
sucksqueezebangblow
posted on 8/12/08 at 03:07 PM Reply With Quote
Looks like I may have to install a throttle cable return spring on the throttle bodies of my 'Busa, in order to get the throttle pedal to spring back. Has any one done this before? If so what works and where did you get a suitable spring?
bob tatt
posted on 8/12/08 at 04:29 PM Reply With Quote
not used one on mine and the pedel comes back every time i sthe cable under a lot of tension
Jon Ison
posted on 8/12/08 at 08:18 PM Reply With Quote
Not usually a problem, does your pedal "swing free" ?
Is your cable nice and free ?
I don't like putting extra springs on the throttle side of things, can make the throttle feel very "twitchy" if its to stiff.
1st point of call for me if all else seems fine would be a light spring on the pedal itself rather than an extra one on the throttle bodies.
richard thomas
posted on 8/12/08 at 08:22 PM Reply With Quote
I put an extra one on the throttle bodies and then two more on the pedal...I want to be sure the bugger closes when it's told!!
The one on the throttle body is just a general purpose spring, it fits where the choke cable used to be.
