sucksqueezebangblow
| posted on 9/12/08 at 04:13 PM |
What choke knob or lever?
I need to fit a choke knob or lever and cable to my 'Busa BEC. I don't particularly like the old fashioned conventional pull and twist
arrangement. Has anyone done anything different? Are there billet knobs or leavers available?
| posted on 9/12/08 at 04:22 PM |
I used a lawnmower throttle lever!
smart51
| posted on 9/12/08 at 04:27 PM |
My choke is connected to the bonnet release lever on the sierra steering column. It is only on as long as you pull it but it doesn't take long
until it will idle on its own.
lotusmadandy
| posted on 9/12/08 at 04:35 PM |
I second the sierra bonnet release lever,
a bike brake cable and ferrule off the bay.
cost me 4 quid and you can't see it.
Danozeman
| posted on 9/12/08 at 08:10 PM |
MInes going on the bonnet pull aswell.
Its hidden and will fill the hole. Mine onyl needs it to fire up easier when its been standing for a while.
You should be able to pack out the pivot some how to stiffen it so it stays on if needed..
Dan
Guinness
| posted on 9/12/08 at 09:56 PM |
Fourth vote for the choke cable fixed to the bonnet release lever under the steering shroud!
Mike
mad-butcher
| posted on 9/12/08 at 10:05 PM |
bonnet pull here aswell
dhutch
| posted on 9/12/08 at 10:51 PM |
I have some string...
whitestu
| posted on 10/12/08 at 09:13 AM |
I bought one of the twist to lock type from CBS.
Link
Stu
mistergrumpy
| posted on 10/12/08 at 11:30 AM |
I'll sixth the bonnet popper too
| posted on 10/12/08 at 12:19 PM |
OK, I'll go for no choke. We had the original blade choke connected to the bonnet release catch on the Sierra column. We never used it and never
needed to, so when we built the ZX12R, we simply didn't bother with the choke. It's just unnecessary weight........
Phil
mackei23b
| posted on 10/12/08 at 04:47 PM |
Bonnet release for me to. The ZX9R wont start with out the choke.
But like others mentioned it does not take long the engine to run without the choke.
Ian
asn163
| posted on 10/12/08 at 09:41 PM |
Hi, are you sure you need one? I second the Hellfire approach. I've never connected up the choke on my Blade and have not had any problems.
Simon
matt.c
| posted on 10/12/08 at 10:14 PM |
Ian
Mine the other day too a good 5 mins to warm up (winter) Bit of a pain in the arse holding the bonnet pull while trying to get the helmet gloves etc
on. Will be changing mine for a pull and twist one soon. Dont really like those old fashioned ones so im also looking for something more up to date.
sucksqueezebangblow
| posted on 23/12/08 at 04:36 PM |
Me too, let me know if you have any luck!
matt.c
| posted on 2/1/09 at 09:37 PM |
^^^^^^ Any luck yet?
