Author: Subject: Engine Position
lsdweb
posted on 10/12/08 at 09:59 PM Reply With Quote
Engine Position
Hi All
My Westfield chassis is now straight and coming back together again.
What do you think about this for the engine position?
jacko
posted on 10/12/08 at 10:03 PM Reply With Quote
The engine needs turning so the prop is more in line with the tunnel
and moving back if needed remove the diagonal box
[Edited on 10/12/08 by jacko]
lsdweb
posted on 10/12/08 at 10:06 PM Reply With Quote
Thanks Jacko - aparrently it needs a bit of misalignment to ensure the prop joints work OK.
jacko
posted on 10/12/08 at 10:10 PM Reply With Quote
This is how i did Roadruners engine
Jacko
fitted engine
fitted engine
jacko
posted on 10/12/08 at 10:15 PM Reply With Quote
gear lever,bearing mount
The plate on the side is were the prop bolts too
adithorp
posted on 10/12/08 at 10:30 PM Reply With Quote
As i understand it the engine and diff' flanges should be parallel to each other but not perfectly in line with each other.
For instance the engine flange could be higher than the diff' but both at 90' to the centre line.
adrian
http://jpsc.org.uk/forum/
designer
posted on 10/12/08 at 11:14 PM Reply With Quote
The centreline of the engine and diff should be parallel to the centreline of the car.
Jon Ison
posted on 11/12/08 at 04:47 AM Reply With Quote
Mine was/is exactly the same as your 1st picture except much further back, been ok since 2002 with no issues.
Flamez
posted on 11/12/08 at 05:52 AM Reply With Quote
Hi wyn, are you powdercoating the chassis because i need some panels doing and perhaps we can reduce the cost.
my build mac1motorsports
motorcycle_mayhem
posted on 11/12/08 at 08:48 AM Reply With Quote
Really, the engine would be better in the passenger seat area, but if you've got to put it where you've indicated, I'll comment on that specifically:
Straighten the engine up a tad. Ideal will be a propshaft a couple of degrees off centre, with all drive flanges parallel with their partners. It won't happen, but you'll get close.
If you've got a reverse gearbox, it's a 3-piece shaft in effect, so you can get the ideal angles and parallelity in the middle and diff. with minor compromises at the engine end. If it's a centre bearing job, then it's a general compromise at both ends. It'll all work, whatever, so don't worry too much.
posted on 11/12/08 at 09:34 AM Reply With Quote
this has been said before - last time it was to stop the UJ seizing.
Well I thought about it and cannot see why that is the case.
With regards to seizing due to lack of movement - so what ? If they aren;t moving and don't need to move then it makes no difference if they are seized or not?
maybe its time for a google ......
twybrow
posted on 11/12/08 at 12:50 PM Reply With Quote
I spoke to Bailey Morris about this issue, and they said the following...
If the misalignment is 0-4 degress, no appreciable problem at all, 5-7 degrees is getting dodgy, and above 7 degrees is a big no no. It has taken me months of blood, sweat and tears to turn my engine, which was sat paralell to the engine bay diaganol. I couldn't get it perfectly aligned with the centreline, but it is now around 3 degrees which BM said is ok.
rj
posted on 11/12/08 at 01:05 PM Reply With Quote
I suggest you fit the exhaust manifold, as well as prop , and try bonnet in place, when i decided on my engine possition it was largley dictated by the exhaust manifold
lsdweb
posted on 11/12/08 at 09:47 PM Reply With Quote
Thanks All
I think I've got it!
Phil (FlameZ) - a quick brush coat of Hammerite probably for me - no fancy powdercoating! There was a guy in Skewen who was very good and prices were good too. Let me know if you want details.
Regards
Wyn
