nitram38
posted on 8/1/09 at 09:02 PM |
R1 throttle cable.....nipples where?
What have you guys done for the nipple on the throttle cable at the throttle body end?
I have a cable from cbs but the nipple is only any good for the pedal end.
I need a cylinder type that I can solder or screw on.
adithorp
| posted on 8/1/09 at 09:16 PM |
I'll have a look what I've got at work tommorow. Got a few solderless (screw) barrel nipples in a box and found one for mine in there. If
you can wait for the post (probably not with your build rate!) I'll stick it in the post. u2u your address.
adrian
http://jpsc.org.uk/forum/
nitram38
| posted on 8/1/09 at 09:19 PM |
adrian
What do you mean "my" build rate, moi?
Cheers Adrian, u2u underway!
001Ben
| posted on 8/1/09 at 09:22 PM |
i used a mountain bike cable and cover - the end with the ball on the end was filled down slighltly to fit into the appropriate slot on the carbs -
for the other end i used a cbs nipple
