Author: Subject: Wiring on ZZR1200
Lightning
posted on 12/1/09 at 11:53 AM Reply With Quote
Wiring on ZZR1200
Pulled apart the wiring loom which was in the car and I understand most of it, but looking at the diagram there should be Throttle position sensor. This was not fitted, presumably this will effect the ECU. Should this be fitted if so how? There is also a pickup coil marked . What is this?
Anyone help ...please
Lightning
posted on 12/1/09 at 11:56 AM Reply With Quote
Oh and what's the read switch????
[Edited on 12/1/09 by Lightning]
minitici
posted on 12/1/09 at 01:20 PM Reply With Quote
Is that Keith Inch's old car?
Lightning
posted on 12/1/09 at 01:39 PM Reply With Quote
yep
minitici
posted on 12/1/09 at 02:08 PM Reply With Quote
In that case, the engine is fitted with ZZR1100 carbs which do not have a tps.
I'm not sure which cdi he was using as he had it wrapped up in Syglass tape last time I saw it.
Do you have the numbers off the cdi unit to check what engine it was intended for?
