chrisg
| posted on 14/1/09 at 12:29 PM |
Blade engine age
Now then,
One of the club members has a fireblade engine which he thinks is pre cat.
How does he check the age of his engine?
Ta muchly
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
| posted on 14/1/09 at 01:01 PM |
Assuming youre talking about for SVA purposes, there is one of two ways;
Check the engine number against those printed in the Haynes maintenance manual, or ring Honda UK for a precise date.
Also, if the number 893 is stamped on the block, there's a good chance it'll be pre 1995. Any other number is most likely post 1995.
Phil
mark chandler
| posted on 14/1/09 at 01:02 PM |
Have a look on the clutch cover side, the engine size will be stamped on a flat, 893cc anything larger will be to new I suspect, these lumps carry a
premium because of this.
Regards Mark
McLannahan
| posted on 14/1/09 at 01:22 PM |
  Blade Engine numbers
chrisg
| posted on 14/1/09 at 02:16 PM |
Thanks Chaps!!!
Chris
Dangle_kt
| posted on 14/1/09 at 05:01 PM |
You are a LEGEND! My engine is a 1994!! PHEW! I was about to write to Honda and spend £30.
Cheers mate! Great news
| posted on 14/1/09 at 05:31 PM |
Most testers will accept the Fireblade Haynes book of lies as the truth!!! Amusing really.
Otherwise blow £30 at Honda UK.
| posted on 14/1/09 at 07:07 PM |
That's ok if you have an engine from 1994 or older but if you have a 1995 engine, you'll need a letter from Honda confirming the exact
date. The blade engine we originally fitted was dated 9th July 1995 so just scraped into the lower emissions test for SVA.
Phil
McLannahan
| posted on 14/1/09 at 08:14 PM |
No problem Dangle!
