Author: Subject: Yamaha R1 5VY Mounting
a4gom
posted on 22/1/09 at 12:30 PM Reply With Quote
My engine came as just that, an engine, no mounting bolts, I'm getting around to the install of the above and need to know what size the mounting bolts are, i've thrown a few bolts I've got kicking around the garage at it but haven't found anything right, funny thread size?
Looks like I need 2 bolts and two lengths of threaded bar.
Does anyone know the answer?
Does anyone have the original items spare that they could be tempted to part with (especially the threaded bars)
[Edited on 22/1/09 by a4gom]
Perfect planning prevents pi$$ poor performance!
adithorp
posted on 22/1/09 at 12:40 PM Reply With Quote
They're metric fine. IIRC M12 fine.
For the 2 long through ones you'd be better off with long bolts if you can find some. Threaded rod can wear the holes.
adrian
http://jpsc.org.uk/forum/
a4gom
posted on 22/1/09 at 04:10 PM Reply With Quote
Thanks Adrian, i'll get a couple of M12 fine and check them out. Presumably the long bar / bolts are M12 as well?
ko_racer
posted on 22/1/09 at 04:56 PM Reply With Quote
Think you'll find they are m10 fine.
Fairly sure it's m10x1.0
yorkshire-engines
posted on 22/1/09 at 06:04 PM Reply With Quote
There M10x1.25 and iv got some if you want them
cheers malc
stuart_g
posted on 22/1/09 at 07:00 PM Reply With Quote
I ran a M12 tap down the rear mounts of my engine. No probs so far.
a4gom
posted on 23/1/09 at 12:16 AM Reply With Quote
Thanks Malc, I may be back for some, I need to get some bushes and work out what length I need first how long are the ones you have?
