a4gom
| posted on 25/1/09 at 07:33 PM |
5vy R1 Clocks what converter, what pick up
I'm putting the R1 engine in, I'm planning on using the bike clocks, I sold my old dash complete with the clocks and speedo pickup.
(doh!)
What do i need to buy now to get the bike speedo working?
yellow box / speedo healer (which is best)
do I need a pick up? I think I read somewhere the standard one is in the bike gearbox so should work?
if not whats the cheapest / easiest option.
Many thanks in advance for your thoughts
[Edited on 25/1/09 by a4gom]
Perfect planning prevents pi$$ poor performance!
adithorp
| posted on 25/1/09 at 08:13 PM |
R1 speedo pick up is in the 'box.
You'll need to correct the reading. "Speedo healer" will do that. I've got a "yellow-box" and it only just
corrects enough on the max setting so go for the "speedo healer".
adrian
http://jpsc.org.uk/forum/
Davg
| posted on 25/1/09 at 08:17 PM |
No worries, R1 5VY has the speedo connection coming off the box, just plug into the loom and then to clocks & you will have a speedo.
Speedohealer will be needed though to correct reading, cost approx £65 squidly.
cheers
D
a4gom
| posted on 25/1/09 at 08:54 PM |
thanks chaps, someone was offering a V3 yellow box for £30 +p&p, I was going to snap it up but if its going to be close i'll not bother,
Adrian, how close is it, what diff / wheels you using?
adithorp
| posted on 25/1/09 at 09:05 PM |
It's an '06 R1 with a Freelander diff. It reads about 75mph at a true 70 mph so about the same as a tin-top.
adrian
a4gom
| posted on 26/1/09 at 01:51 PM |
I suppose its quite a complicated thing to work out on paper what % adjustment is required, bike sprockets, bike tyre circumference etc...
I've got a 3.89 diff and 185/60/13 tyres at the mo, money will dictate that that's what its going to hit the road on but I am aware more
rubber and a different diff may be required further down the line.
I've done some calcs and I think I need to adjust by -39.5% ???
[Edited on 3/2/09 by a4gom]
