Author: Subject: metalistic or bonded bushes? supplier?
a4gom
posted on 26/1/09 at 06:08 PM Reply With Quote
metalisic or bonded bushes what ever you call them, two bits of tube with rubber in between!
Anyone got a good supplier for 10mm internal, 22mm outside dia?
RS do them its going to cost £47 for 12 is that good?
The outer is only 20mm long and I would have preferred some a little longer but haven't managed to find another supplier.
[Edited on 26/1/09 by a4gom]
Perfect planning prevents pi$$ poor performance!
andylancaster3000
posted on 26/1/09 at 07:01 PM Reply With Quote
Try RS. You can get them in a variety of sizes. We bought some, though only ended up using one. They seem to be much stiffer than car type versions which is good.
Infact, there you go:
bushes
Ignore my post!! Jumped the gun and failed to read the RS bit. Seems you've found them already
[Edited on 26/1/09 by andylancaster3000]
big_wasa
posted on 26/1/09 at 07:17 PM Reply With Quote
loads on ebay.
They are what "the book" used for the wishbone bushes.
they are 22mm outer 36mm long and the center hole is 3/8 but not a big job to take them out to 10mm.
designer
posted on 26/1/09 at 07:46 PM Reply With Quote
Any fotor factor can supplky matalastic bushes; much cheaper than Ebay.
designer
posted on 26/1/09 at 07:47 PM Reply With Quote
Any motor factor can supply metalastic bushes; much cheaper than Ebay.
