Author: Subject: Noise reducing tips
marmot0
posted on 4/2/09 at 02:49 PM Reply With Quote
Noise reducing tips
Have my SVA retest on Friday after failing on Noise (108dB). The engine is a CBR954.
I have now fitted the following:
Airbox
Restrictor in the exhaust.
Lagged the engine bay with accoustic foam.
Can anybody think of anything I have missed
tegwin
posted on 4/2/09 at 02:53 PM Reply With Quote
Do you have things rigidly mounted?
like engine, exhaust etc? If you can reduce the amount of vibration that resonates around the chassiss that might help!
www.verticalhorizonsmedia.tv
smart51
posted on 4/2/09 at 02:59 PM Reply With Quote
fit a bigger silencer. Really, it is the best way.
marmot0
posted on 4/2/09 at 03:04 PM Reply With Quote
Already have a large 6" can fitted
l0rd
posted on 4/2/09 at 03:15 PM Reply With Quote
fit a cat?
Mr Whippy
if its mounted rigid then the car body becomes a loud speaker. I did this on the Falcon with the v6, utterly horrable racket right through the whole car, changed it to rubber mounts, quiet as a mouse
posted on 4/2/09 at 05:09 PM Reply With Quote
If you have can, rotate the tailpipe end so it points to the ground or even back uner the car away from the testers sound meter.
Guinness
posted on 4/2/09 at 05:50 PM Reply With Quote
Ever seen a Jensen Healey engine bay?
They have / had a silencer before the airbox!
Good luck with the test.
Mike
ReMan
posted on 4/2/09 at 09:29 PM Reply With Quote
Mike
Well thats a new one on me, I never knew that!
[Edited on 4/2/09 by ReMan]
iiyama
posted on 5/2/09 at 08:38 AM Reply With Quote
How about deadening some panels with acoustic material? Get it off the bay for a few quid and stick it to the inside of thin panels. Kills the reasonance.
If its broke, fix it. If it aint broke, take it apart and find out how it works!
