Author: Subject: Old ZX10 cam question
craig_007
posted on 4/2/09 at 03:59 PM Reply With Quote
While checking my valve clearances today I noticed my inlet camshaft was rather pitted,I've now removed both cams and checked with a micrometer,both my cams are below the sevice limit(very worn) my exhaust being worst of the two.
Anyway I'm wondering if I could use a pair of ZZR1100 cams to replace my orginal zx10 items as the ZZR has greater lift or can someone reccomend a place where I can buy a pair of cams
Just a thought !!!
[Edited on 4/2/09 by craig_007]
russbost
posted on 4/2/09 at 05:38 PM Reply With Quote
A lot of ZZr bits fit the ZX 10 but don't know if camshafts are swappable.
Someone on here must have some cams knocking about, surely???
Guinness
Hi Craig
I've got a spare (old) set of ZZR cams in the pile of engine bits out the back. If they are compatible let me know and I'll dig them out for you.
Mike
craig_007
posted on 4/2/09 at 05:48 PM Reply With Quote
Hi Mike,
Thanks for that offer mate,I've been searching the web to see if they are compatible but so far have turned up nothing,I've also checked my haynes manual but it just tells me the the ZZR has more lift,I did however notice the ZZR head is different to my ZX10 head so I'll continue with the search !!
Craig
minitici
posted on 4/2/09 at 07:10 PM Reply With Quote
I've got a box of old zx10 cams out in the hut, don't know if they are serviceable or not. Might even have a pair of ZZR1100 cams in a head with a couple of bent valves......
craig_007
posted on 4/2/09 at 07:38 PM Reply With Quote
I quite fancy putting cams in with a little bit higher lift thats why I intially thought of the ZZR as it has slighty more lift
If I could find out if I could get away with fitting the ZZR head that would be ideal as the valves are bigger too !! (At this rate I would be better dropping a complete ZZR unit in lol)
Rod Ends
posted on 4/2/09 at 07:41 PM Reply With Quote
Parts diagrams at kawasaki.com include parts numbers.
craig_007
posted on 6/2/09 at 01:34 PM Reply With Quote
Thanks for all the replys guys,
I have now found out that ZZR cams will not fit a ZX10 a model,.
It turns out that the Kawasaki "A" model is of poorer spec due to it's cylinder head set up.
It is also not possible to swap the head from ZZR onto an "A" model due to a different block set up although engine casings and engine mountings are the same,Howevere on the ZX10 b models the ZZR parts are interchangable(cams,head etc)
Thanks for the offers anyway.
Craig
craig_007
posted on 9/2/09 at 09:48 PM Reply With Quote
Hi Guys,
Hoping someone can shed some light on this for me.
I have just got 2 fairly new cams for my motor from a guy that breaks bikes locally,Anyway now I've got them home I have noticed the part numbers do not match my orginal cams and I also can't see them on Kawasaki parts either,Also my new cams have adjustable sprokets(similar to verniers) Again my orginal cams had fixed sprokets !!
I'm wondering if anyone has the cam part number to hand.Here is the number of my new cams KCF1001.
Cheers Craig
Coose
posted on 10/2/09 at 02:49 PM Reply With Quote
Originally posted by craig_007
Hi Guys,
Cheers Craig
Hmmmm.... Maybe a regrind by Kent Cams?
Spin 'er off Well...
