Author: Subject: 893 Fireblade Speedo/Gages - How to connect?
phil_far
posted on 4/2/09 at 06:11 PM Reply With Quote
How do you connect the speedo (bike clocks) to the engine (893 blade)? Basically how do you make it work?
Philip
LBMEFM
posted on 4/2/09 at 08:04 PM Reply With Quote
Depends what loom you are using, I adapted the original loom and it just plugs in at the back using the two plugs.
posted on 4/2/09 at 08:08 PM Reply With Quote
The clocks just plug into the loom. The speedo sensor picks up from the bolt that holds the sprocket on. It has a round piece of plastic with a hexagonal insert that is positioned over the bolt head. Obviously, in a BEC application the pickup will not fit. On our first Blade engined Indy, we manufactured a bracket to run the wheel on the output flange of the diff. I'm sure there's some pictures on our website which show it better.
Phil
[Edited on 4-2-09 by Hellfire]
posted on 4/2/09 at 08:54 PM Reply With Quote
25th March 2004
A description is on here how we did it - it lasted about 5000 miles before it's life was prematurely and abruptly stopped.
ReMan
posted on 4/2/09 at 09:17 PM Reply With Quote
Or use a later blade gearbox speed sensor and point that at some magnets on the prop or diff...
phil_far
posted on 5/2/09 at 05:22 PM Reply With Quote
Thanks guys, I think that the speed sensor was missing from my loom that is why I was confused.
Philip
