Author: Subject: oops :(
james h
posted on 18/2/09 at 05:09 PM Reply With Quote
oops :(
I bought an original airbox off ebay for my 4xv R1 engine. Took delivery today.
I have tried it on, but now its far too tall! (even with bonnet bulge).
Any solutions? I can't rotate it 180 degrees as the carb inlets are not equally spaced.
Maybe I could run some flexible ducting from the carbs to the airbox? Would this be ok?
James
tomprescott
posted on 18/2/09 at 05:18 PM Reply With Quote
I've seen on ebay bike carbs on car manifolds that have 4 individual little conical filters, they take up loads less space - should be able to find them quite easily.
Pdlewis
posted on 18/2/09 at 05:24 PM Reply With Quote
it can be roatated (just need to cut the plastic lip off) but that was still to tall for my MNR
Build Photo Album
Updated 05/02/2009
mad-butcher
posted on 18/2/09 at 06:11 PM Reply With Quote
I very carefully cut a rectangle around all 4 intake holes turned the filter around then reattatched, difficult to explain the R1 is in another garage but will try and get a picture to explain what I mean,
Basically you end up with a rectangle of plastic that fits all 4 inlets and an air box with a rectangle missing if you now rotate the filter 180 deg the 2 parts should mate up, now either have it plastic welded or make up an alloy 3mm plate and pop rivet on.
nah ! a photo would be easier
tony
[Edited on 18/2/09 by mad-butcher]
james h
posted on 18/2/09 at 06:29 PM Reply With Quote
tony
I think I get what u mean, you cut around the four holes to get a long oval, then rotate the filter 180 degrees? Using a backing plate to seal the remaining gaps?
[Edited on 18/2/09 by james h]
mad-butcher
posted on 18/2/09 at 06:42 PM Reply With Quote
you got it in one, if you make a carboard template before you attack it
