bassett
| posted on 25/2/09 at 10:17 PM |
Covering R1 clock for SVA
Hi ive made a hole in the centre of the dash for the R1 clocks which i will sandwich together after sva. Right now to get to sva how have others
radiused theirs to get it through - pics would be great.
Ive been thinking about mounting behind the scuttle so it is visible through a perspex panel. Can anyone see a problem with this idea?
Adam
jimgiblett
| posted on 25/2/09 at 11:42 PM |
On my Phoenix I used some high density adhesive backed foam and created a rubber frame.
To make the template photocopy your clocks and use this as a guide and then use either a sharp craft knife or a hot wire.
- Jim
bassett
| posted on 25/2/09 at 11:46 PM |
Cheers Jim, I think weve got some mega thick foam lying around that we planned to use to the seats and steering wheel so that might be worth a try
just need to find a suitable adhesive.
Adam
Pdlewis
| posted on 25/2/09 at 11:49 PM |
Hi Adam,
I have the same I wasnt sure if the 5pw clocks had the same radiouse issues as the newer clocks
Build Photo Album
Updated 05/02/2009
bassett
| posted on 25/2/09 at 11:58 PM |
Mines outside the exluded area of the steering wheel and it does look like it has some protuding edges so to be on the safe side il do it. Just
annoying with these little things at the moment that i know will take quite a while
[Edited on 25/2/09 by bassett]
spdpug98
| posted on 26/2/09 at 08:29 AM |
Looks like I will have the same problem, I have been wondering how I will over come it.
My Blog: http://spdpug98.wordpress.com/
MakeEverything
| posted on 26/2/09 at 08:40 AM |
Didnt i read somewhere that if its behind the steering wheel, the radius isnt a problem?
Kindest Regards,
Richard.
bassett
| posted on 26/2/09 at 09:35 AM |
It is but we have had to put ours in the middle as with the mnr scuttle it is on a curve so is easier to mount it central and is not within the
excluded zone
