bassett
| posted on 5/3/09 at 01:31 PM |
R1 Thermostat
Hi, Does anyone know if you can cut and weld the standard metal pipe that joins the thermostat housing to the cylinder on a 5pw R1? Reason being id
like to keep the thermostat 6mm hose and if i could do this it would fit under the bonnet.
Adam
afj
| posted on 5/3/09 at 01:41 PM |
cant you extend it out the way with some extra hose, think its been done before
eerrrrrrrrrrrrrrrr
dave107
| posted on 5/3/09 at 01:46 PM |
One of the guys who's got an MNR build site has moved it with extending pipework onto those standard pipes, have a look around, if i have time
tonight i will find the site and let you know.
bassett
| posted on 5/3/09 at 02:48 PM |
I have seen that but its just a bit messier, lots of extra hoses=£, time finding measuring etc and cutting the top hose metal pipe. for cost and time
i thought it may be easier to shorten the stock thermostat to head metal pipe but id like to know if it can be welded or not as im unsure of the
material as its a goldy colour.
jimgiblett
| posted on 5/3/09 at 03:02 PM |
I think the yellow colour is only cadmium plating on steel.
Are you talking about the small bleed pipe? If so if you swap the thermostat end with one from a 5JJ it points inwards. I think I have one at home
which I bought from Malc as I was going to do this mod on the Fury. In the end I moved the engine
I'll have a dig around later.
- Jim
[Edited on 5/3/09 by jimgiblett]
bassett
| posted on 5/3/09 at 05:30 PM |
yeah the outlet on the stat housing, If youve got one that would be great Jim if not do you think it can be cut and welded?
jimgiblett
| posted on 5/3/09 at 07:22 PM |
Have sent you an email off list.
Jim
