bitsilly
posted on 9/3/09 at 05:42 PM |
The Hayabusa
Is there a straight forward list of the best installations of the hayabusa in BECs Or could we decide one!
I was told the new one (don't know numbers/names.dates) can go in with no mods at all.
The turbo ones seem to lose reliability or is there a way around that? Is turboing a post bike mod?
Are there different bores or are they a mod?
Excuse my iggerence but any pointers would be appreciated.
Ed
bob tatt
| posted on 9/3/09 at 06:06 PM |
dont know much about the k8 engine so i wont comment on it, although i assume it will not be radically different from earlier ones.
as for teh turbod engines it all depends on how well the work is done in the first place and how hard they are driven. i know a couple of people that
have turbo bikes, one has done 20000 on it with no major problems. he does mostly touring and some straight line racing as well as top speed events.
and the other lad has used it mainly for sprinting and on the road, and hes had nothing but trouble ranging from melted pistons to a bent rod. both
these instalations were done by different companys. the most reliable of the two is a big cc conversion, i wont say who did the other as its alittle
unfair to comment on something that has been riden very hard for most of its life.
if by different bores you mean different capacities these are achieved by fitting a stroker kit with a different crank and pistons. although if you
want to go really silly they can be rebored.
ive found mine to be more than enough for me i cant see anywhere you could really open up a turbo.
one thing to bear in mind the turbo bikes are through the gears so fast , where as the bec will be on boost a lot longer this is where the problems
arise with extra stress on the engine over a prolonged period. i beleive mr fisher had this problem when trying to turbo his previous 10r
rob
yorkshire-engines
| posted on 9/3/09 at 07:42 PM |
Hi All
ok the 2008 busa is exactly same the 99-07 model the output shaft is bigger and the injection and wiring are different
there 1340 cc and nearly 200 bhp
the 08 crank can be fitted into earler models and makes around 1320cc
turbo if its done correctly you can acheve around 300 bhp and as much as 750 bhp all reliable power
also supercharging is the easiest way for more bang for your bucks
cheers
ps 08 busa in today 1100 miles complete wth all gear around £3800
bitsilly
| posted on 9/3/09 at 08:13 PM |
So if I jumped on the band wagon and got a kit suitable for a hayabusa from 99 on, I could fit the K8 engine?
If so I will ring soon Malc, how often do they come in, and who does the superchargers?
bitsilly
| posted on 9/3/09 at 08:20 PM |
Is TTS the way to go?
bob tatt
| posted on 9/3/09 at 08:46 PM |
i was talking to tts at auto sport and there kit looks very good. personally i would go that route a lot more progressive than the turbo route.
is this a serious option if so id love to know how you get on with it
rob
daniel mason
| posted on 9/3/09 at 08:54 PM |
what sort of price is a supercharger kit for a bike engine?
bitsilly
| posted on 9/3/09 at 08:58 PM |
I'll keep you posted Rob, just have to decide what chassis to use now!
| posted on 10/3/09 at 12:27 PM |
It'll cost you 4K at least for a Rotrex Supercharger conversion.
Phil
sucksqueezebangblow
| posted on 10/3/09 at 02:22 PM |
Take a look at this link
bitsilly
| posted on 10/3/09 at 04:46 PM |
It was the TTS one I was considering, but a couple of people have suggested a supercharged R1 may be a better bet??
| posted on 10/3/09 at 05:39 PM |
Note the very important but often overlooked word from Then consider what else you're gonna need to get it to work and get a price to
include that too.
Phil
sucksqueezebangblow
| posted on 10/3/09 at 06:10 PM |
I'm guessing that the Busa being bigger, is stronger and better able to handle the boost in power (particularly the gearbox). Also there are
lots of after market goodies for the Busa as they drag race them and speed trial them.
| posted on 10/3/09 at 06:16 PM |
Yep, I'd agree with Sucksqueezebangblow. If ever there was a suitable bike engine for strapping a supercharger/turbo too, it has to be the Busa.
Phil
Jason Fletcher
| posted on 10/3/09 at 10:36 PM |
there has been some talk that the 08 Busa may not be suitable for turboing as it has titainium valves??? Anyone know if ones been done yet?
jason
sucksqueezebangblow
| posted on 11/3/09 at 09:55 AM |
jason
I think it is more to do with the increased compression ratio of the 08 'Busa. The earlier engine has a lower compression ratio and is therefore
more suited to forced induction.
bitsilly
| posted on 11/3/09 at 10:13 AM |
Spoke to Paul at TTS.
I would have to turn up with a working engine in the car and they would do the installation with intercooler and induction for around 4.5K I would
also have to buy a power commander c£250.
Engine would cost around £3.5
Say £8.5K all in?? A lot of dosh, but it should frighten passengers!
TTS have supercharged quite a few hayabusas but not any K8 ones.
motorcycle_mayhem
| posted on 12/3/09 at 09:19 AM |
You need to look at the 'package'. You need to look at your intended use. You need to check your pocket depth. You can then proceed.
Quite possible to bolt on a 'charger have some fun on the road/car park/track without too much else. The 'Busa is a good strong lump.
Start adding track days/slicks/other and weak links will show up all over the place. Before you know it, you're into rods, billet clutch
baskets, dry sumping, Nova gearboxes and all that. I know this.
The Carrilo's I've just fitted were reassuringly expensive, the wife's salary for the month will just about cover them.....
All that said, an early 'Busa is now not so expensive as it was, probably viable to treat as a consumable and blow the standard thing to hell
with all the bolt-ons and then get another??
