Major Stare
| posted on 10/3/09 at 10:45 PM |
BEC... now a bit high !
Took the X-flow out my Westfield and in the process of fitting an R1.
The front end is now too high, the existing SPAX now need to be replaced.
What shock/spring settup do i need?
Jon "FISH"
Paul TigerB6
| posted on 10/3/09 at 11:06 PM |
Maybe just lowering the spring seats, or softer springs will do the job. Take about 20% off the spring rate of what you currently have if you feel the
car is too stiff. Many dont bother changing the springs anyway.
What shocks do you currently have??
westf27
| posted on 10/3/09 at 11:07 PM |
you probably just need to replace the spring with a lower rate to compensate for the added lightness.
555
ReMan
| posted on 11/3/09 at 07:24 AM |
225lb on mine with 'Blade and large driver!
Danozeman
| posted on 11/3/09 at 08:32 AM |
Shorter springs?
Dan
