bassett
| posted on 14/3/09 at 04:25 PM |
Lengthening R1 Rectifier wires?
Hi I lengthened my 02-03 r1s rectifier wires to get it under the scuttle and now it when it runs they get quite hot - is this normal? i also noticed
a small whilst of smoke. Anyone know what wattage wires i should be using? think i used 17amp 200w wire but i could use 27amp 325w wire. Ive also used
bullet connectors would soldering and heat shrinking be better?
On the off chance i wired it wrong does it matter which ray round they go as they were all white wires?
Adam
| posted on 14/3/09 at 04:49 PM |
Rectifiers need quite chunky supply wires. After all, even a bike alternator will give 40A. I wouldn't trust a bullet connector to work with
half of that!!! I'd use something chunky and solder / heat shrink as you've suggested.
bassett
| posted on 14/3/09 at 06:10 PM |
Thanks ben, the standard wires not overly thick looks somewhere between the thickness of 17a and 27a wire i have but i know the wire i have has quite
thick insulation so il try the thick stuff and solder.
cheers
adithorp
| posted on 14/3/09 at 07:04 PM |
I extended mine and used thicker wire than the original. They still get warm. Done 2000 miles like that though.
I'd check your connections though if you got smoke!
adrian
http://jpsc.org.uk/forum/
motorcycle_mayhem
| posted on 14/3/09 at 08:07 PM |
My Suzuki GSXRs have 25A wire, but it's the OEM plug and socket at the rectumfrier that cause problems. It's a simple 6-way blade
connector that just isn't up to it, it gets hot and melts.
I use something more appropriate from Maplin.
bassett
| posted on 14/3/09 at 11:28 PM |
Cheers guys getting on this tomorrow and its only a short extension so should be a quick and easy fix. Lucky i found it today as it was running with
the scuttle off as it has been hidden for the previous runs
