Author: Subject: Hunting and Stalling
mistergrumpy
posted on 6/4/09 at 02:06 PM Reply With Quote
Another question related to my ZX9. It's now ticking over at around 1100rpm and then at somewhere between 12 and 16 seconds the revs will rise to around 1500rpm and then drop right down and stall. Any ideas? I'm playing with the mixtur at the mo but it's not really affecting it and I've stripped and cleaned the carbs again.
dinosaurjuice
posted on 6/4/09 at 02:35 PM Reply With Quote
my trike did this if i turned the fuel tap off while it was running.
maybe theres a blocked supply pipe or dodgy pump?
hughpinder
posted on 6/4/09 at 03:25 PM Reply With Quote
Sound like its using the fuel in the carb bowl then stopping - partially blocked fuel line?
hugh
mistergrumpy
posted on 6/4/09 at 03:26 PM Reply With Quote
Hmm. Possibly, something I've not looked at. I don't have a tap but I can check the delivery.Cheers, I'll have a butchers at that.
Any more ideas?
cloudy
posted on 6/4/09 at 03:54 PM Reply With Quote
Yup sounds awfully like the float bowls running dry...
www.warnercars.com
mistergrumpy
posted on 6/4/09 at 05:49 PM Reply With Quote
Think I'll check the fuel pump's running then. I did play with the wires after removing an immobiliser.
mistergrumpy
posted on 6/4/09 at 07:03 PM Reply With Quote
Fuel pump's fine. It's good enough to get it right down to my elbow!
Just thinking. Once the engine's stalled it'll start again after a few cranks, not right away so it's like the fuel's being used quicker than it can be replenished.
I cleaned the float bowls and the inlets were dirty so I cleaned the filters on them.
Any further ideas?
[Edited on 6/4/09 by mistergrumpy]
mistergrumpy
posted on 7/4/09 at 04:56 PM Reply With Quote
Ha ha! I think I've done it. There's a breather pipe on the carbs that leaked fuel when I bought the engine nearly 3 years ago. At the time I thought it was a coolant pipe and had a bit of manky tape on the end. When I replaced the master cylinder a few weeks ago there were little caps in the inlets and I found one to be just the right size to replace the manky tape. Here's the problem I think.
I think that air was just getting by with the tape but with the cap I think it was sucking until it couldn't suck any more then choking and stalling.
I've just started it in the garage and its working again! Pity I cancelled my SVA retest which would have been tomorrow morning as well At least I won I suppose.
cloudy
posted on 7/4/09 at 05:13 PM Reply With Quote
That'll do it!
www.warnercars.com
mistergrumpy
posted on 7/4/09 at 05:16 PM Reply With Quote
I'm well pleased. I've just to wait for another mixtur screw tomorrow as one had a split O ring when I looked at it then I'm going to give it a run up to temperature and see how it behaves.
