Author: Subject: Paddleshift spring question?
nitram38
posted on 12/4/09 at 02:08 PM Reply With Quote
I have a cable paddleshift on the Motaleira which works, but is it supposed to return to midway position?
I seem to be getting very slight drag on the cable (8ft long with one long bend)which is stopping the gearlever returning to the idle position (hope that makes sense.)
It doesn't affect gear selection.
Have any of you put springs to help yours return?
[Edited on 12/4/2009 by nitram38]
YQUSTA
posted on 12/4/09 at 03:40 PM Reply With Quote
I have a cable and a stick shift connected at the same time and have no issues.
But i did to start with.
Check the entry/exit points to the cable ends that is what caused mine too much angle at the entry/exit at the paddle end.
edit: no spring on mine
[Edited on 12/4/09 by YQUSTA]
nitram38
posted on 12/4/09 at 03:43 PM Reply With Quote
They are straight. I think that it is just the length of the cable.
The drag is not that severe. I am thinking of putting a spring either side of the paddle to help centralise it.
locoR1
posted on 12/4/09 at 03:52 PM Reply With Quote
I had a similar problem with mine it turned out to be the little rubber boots/dust covers at each end dragging after i wiped the grease off! worth a try just pull the boots back out the way and see if it makes any difference.
If not it looks like springs are your only option.
Check out my CB500T Cafe Racer build diary
nitram38
posted on 13/4/09 at 05:39 AM Reply With Quote
I've just had a thought.
Will having return springs affect my flatshifter? Will it think that the cable is being operated?
:{THC}:YosamiteSam
posted on 13/4/09 at 01:08 PM Reply With Quote
what engine?
if its a busa iv just had this problem and solution
gear selection spring
nitram38
posted on 13/4/09 at 01:19 PM Reply With Quote
R1......I saw your thread. Good luck with fixing yours. It looks a bit more involved than mine.
I'm just waiting on a couple of return springs to be posted to me, so that I can just clip them either side of my paddle.
nitram38
posted on 25/4/09 at 12:58 PM Reply With Quote
Well I think I sorted it!
Thanks for the advice on the boots locoR1.
Some copperease under them helped a lot. Springs helped a bit more.
I had some issues selecting gears but I played around with the cable outer adjuster as it was limiting the travel in 1st gear one way or 2nd upwards the other way.
There is a sweet spot in between.
