Jon Ison
| posted on 13/4/09 at 09:08 AM |
Got a blown busa ?
I am desperate for this banjo bolt as shown or should I say not shown in this photo,
Beer tokens waiting for a suitable donor.
Mr Whippy
| posted on 13/4/09 at 09:16 AM |
If you go to a hydraulics supplier they will have them in stock, find a bolt that screws in to the thread to show them, you'll need new brass
washers too
[Edited on 13/4/09 by Mr Whippy]
greggors84
| posted on 13/4/09 at 12:16 PM |
If you can find out the thread Jon I may be able to help you.
Chris
The Magnificent 7!
Jon Ison
| posted on 13/4/09 at 03:51 PM |
will try, I only have 1/8 its bigger than that and 1/2 taps smaller than that, so maybe 1/4 or 3/8 but thread not sure.
smart51
| posted on 13/4/09 at 05:18 PM |
It is Japanese so probably metric.
Jon Ison
| posted on 13/4/09 at 05:20 PM |
The main oil gallery blank is 1/2" so most likely not ?
iiyama
| posted on 13/4/09 at 07:48 PM |
1/2"?? You sure?? Thought all the threads on my busa were metric, at least anything that Ive had apart is definatly metric.
There are 4 banjo's on the busa, two run an oil line to the cam chain adjuster, and two are for an oil feed to the head, (i think!). All of
these are M10.
Pretty sure Ive got one or two Jon, drop me a line and Ill try and check tomorrow.
Ian
If its broke, fix it. If it aint broke, take it apart and find out how it works!
Jon Ison
| posted on 13/4/09 at 08:06 PM |
Maybe I'm going daft ?
I just recall taking the blank out and I'm pretty sure it was 1/2" but you both have me wondering now.
Anyhow, please check if you have one for me, would be muchley appreciated.
eta just been for a look see, the oil gallery, I now know where I got the 1/2bsp idea from, I found lurking in the garage a odd ball fitting that
fitted to adapt it up to 1/2 (what I wanted for the accusump) it measures 15mm ish as for the missing banjo bolt a M12 bolt wobbles freely in the hole
[Edited on 13/4/09 by Jon Ison]
Phil.J
| posted on 14/4/09 at 07:19 PM |
Busa main oil gallery plug is 14mm x 1.5 or 1.25, can't remember which.
