off-road-ham
| posted on 15/4/09 at 06:47 PM |
starter motor power
Hi, does anyone know how much current a fireblade starter(or similar) will take when in use.
I am looking to get a speed controller so as to have some control rather than simple on/off.
thanks in advance for any usefull info.
Tony
redscamp
| posted on 15/4/09 at 07:09 PM |
you say use,
they are not for 100% duty cycle
i hope you dont want to run it for more than a few seconds
off-road-ham
| posted on 15/4/09 at 07:16 PM |
I just want to be able to control the speed and not have it jump form stop to full speed.
Also I think having a small amount of power to slowly rotate the cog will help it engage and show to IVA man that it is a thought out install rather
than a bodge quick fix that will "fall off" after the test.
Hopefully that will help set a "good mood" for the test.
Other than the test I don't forsee much use.
Rod Ends
| posted on 15/4/09 at 07:40 PM |
Haynes ZZR1100 manual has no specs. on the starter itself but it's powered via the main 30A fuse.
So, less than (30A x 12V) 360Watts.
rf900rush
| posted on 15/4/09 at 08:36 PM |
Starter solidnoid is usually fed by a 30Amp fuse.
Look at 200A may be more if stalled.
If you need a more realistic figure U2U me and I will try to measure the Current consumption on my removed RF900 engine.
Martin
Rod Ends
| posted on 15/4/09 at 09:03 PM |
There's no solenoid on the ZZR just a relay with integral fuse to the starter supply.
