40inches
posted on 21/4/09 at 03:12 PM |
Leccy reverse gear pinion price!!!!
Just got a quote, £135 Is this a bit on the high side? The machining comes in at £82 on top of the cut gear blank with 22mm standard bore.
I don't like the way the MK spur gear flange only extends half way down the mounting bolt hole. The prop end on the origanal fitting uses a
spigot to locate it on the diff flange, I have asked for the gear to be machined the same way, the same as a good quality wheel spacer replicates the
hub centric fitting.
Any one got it done cheaper?????
mcerd1
posted on 21/4/09 at 03:43 PM |
I might have some ideas - have you got any sketches / pics ?
btw - this cost £130 for the machining, and thats after I bought the alloy and the trigger wheel
[Edited on 21/4/09 by mcerd1]
richardlee237
posted on 21/4/09 at 04:07 PM |
For a one off gear, in the correct material and properly machined not just chomped out, the price seems reasonable IMHO.
A lot of the cost for this sort of machining is setting up. So, a small gear can be relatively costly.
Quote Lord Kelvin
“Large increases in cost with questionable increases in performance can be tolerated only in race horses and women.”
Quote Richard Lee
"and cars"
40inches
posted on 21/4/09 at 05:22 PM |
The £82 was for machining the bore and counter bore, the actual gear is a stock item.
Gear
clairetoo
posted on 21/4/09 at 07:47 PM |
£82 for that little bit of machining
If you can bung the gear in the post to me , I'll do it for a drink (JD `n coke )
or three
Its cuz I is blond , innit
Claire xx
Will weld for food......
40inches
posted on 22/4/09 at 12:49 PM |
If you can bung the gear in the post to me , I'll do it for a drink (JD `n coke )or three
They have a menu for any post production machining, £36 + VAT for any bore over 50mm but only charge around £5 for cutting a keyway? Go figure.
Going to see them this afternoon for a breakdown of costs.
Is that 3 glasses of JD or 3 bottles Claire?
