Jon Ison
| posted on 22/4/09 at 05:15 PM |
Even more busa questions.
Undecided what to do with fueling, I have a std pump but how involved is modding the fuel rail and dishing the std pump ?
Still looking for that elusive banjo bolt, there must be a blown busa sat in a locostbuilders garage somewhere than can donate the bolt ?
iiyama
| posted on 22/4/09 at 05:43 PM |
Heres my set up Jon, but be aware that it was not Locost!
As for the banjo, refresh my memory! There are two flexis used for oil on the Busa, (unless this is for the oil cooler?). One lubes the cam chain
tensioner and the other is at the back of the engine close to the exhaust. The latter I replaced with a stainless hose as I felt that it was going to
get pretty hot in this area. The former Ive removed completly as I have a manual cam tensioner fitted. I have the banjos for the hose that I replaced
and they are surplus to my requirements!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
Jon Ison
| posted on 22/4/09 at 06:04 PM |
hi its the one at the bottom of the engine water pump/sprocket side, the largest one on there.
What did you do fuel rail wise, swap or modify ?
Steve Hignett
| posted on 22/4/09 at 07:49 PM |
Jon,
Try Malc at MB Customs for the banjo bolt. He's a top fella and should be able to help - just don't mention you are from here cos he was
kicked off for offering to sell a complete R1 engine for the £300 it cost him...
MBCustoms
01323 743733
[Edited on 22/4/09 by Steve Hignett]
iiyama
| posted on 22/4/09 at 08:15 PM |
Fuel rail is this:-
http://www.bigccracing.com/shop/product.asp?idproduct=34&source=thumb
Fuel pump and pressure reg are Aeromotive.
Ill take a gander tomorrow re banjo.....
Jon Ison
| posted on 22/4/09 at 08:55 PM |
I was thinking a more locost version like drill n tap the rail and and a pressure reg/return, but what pressure and as/can it be done ?
richard thomas
| posted on 22/4/09 at 09:46 PM |
I have a modded rail - just as you said, has a return welded to the end alloy pipe between the throttle bodies. Fed by a sierra fuel pump with a
pressure regulator after the rail to adjust the pressure as required
iiyama
| posted on 23/4/09 at 01:32 PM |
Fuel pressure on the Hayabusa is 43psi
sucksqueezebangblow
| posted on 23/4/09 at 02:42 PM |
There is no need to modify the fuel rail.
Run the high pressure fuel line from the fuel pump (best placed under or level with the bottom of the tank) to a fuel pressure regulator, and then run
a low pressure line from the regulator return outlet to the fuel tank return. Set the regulator to the desired fuel pressure (I think it is 3 Bar but
will check and edit). I attached a pressure guage to the regulator to measure this. You then have fuel in the high pressure fuel line at the correct
pressure.
All that then remains it to put a T-piece in the high pressure fuel line and use it to run a high pressure fuel hose to the fuel rail. No need for a
return from the fuel rail or any modifications to it.
Please note I have not included filters in my description but it is adviseable to put one on the low pressure side of the pump, and some double up by
putting one on the high pressure side a well.
richard thomas
| posted on 23/4/09 at 06:02 PM |
Having a t-piece in the rail helps prevent airlocks in the rail- I suffered from this.....
Jason Fletcher
| posted on 23/4/09 at 09:03 PM |
My Busa engine is a K8 and has the plastic fuel rail which has a centre feed so I simply used a normal regulator with the three fittings. one of the
top fittings was the supply, the other one was the fuel rail feed and the one at the bottom was the return. Works perfectly and really easy to do.
You can just see it on this pic here
Jason
cosmick
| posted on 24/4/09 at 07:49 PM |
Busa Fuel Pump
I Have a Megabusa and have fitted a Suzuki Hayabusa in tank Fuel Pump. there are a number of reasons. Firstly its the right pump for the job. it
regulates the pressure inside the tank thus doing away with the need for a pressure regulator at the engine side and you only need one pipe to supply
the rail. this makes the installation much neater. i have also moved the fuel connector on the rail to the other end of the throttle bodies so that it
is closer to the bulkhead.
Hope this helps.
Jon Ison
| posted on 24/4/09 at 08:45 PM |
mmmmmm, now there is a plan. Thank you.
As for the banjo, still desperatly seeking one.
cosmick
| posted on 28/4/09 at 11:45 AM |
Busa Fuel Pump
Here is my set up. i think you will find it is neat and tidy as it looks
standard.[img]http://locostbuilders.co.uk/upload/a935658-MEGABUSA_046[1].jpg[/img]
