INDY BIRD
| posted on 25/5/09 at 08:39 PM |
ZX10r Turbo Indy
Hi
just thought i would update on how things are progressing with the engine,
Now got the engine back from MB customs who has done the works so should be able to cope with what i throw at it,
it has had
new MTk turbo pistons
Falcon rods 1mm shorter
new strengthend engine bolts (pull the head together better)
uprated cam chain and manual tensioner
uprated clutch springs
cometic head gasket
Compression now 9-8-1
uprated valves and spring
Valves is what caused pauls old engine to blow pic attached of what was removed from this engine,
+ some other small bits and bobs like billetsreed valve covers
So now the enviable task of intalling the engine and bolting on the turbo kit etc and setting all up,
Should be good for 250bhp at wheels around 6psi, on pump fuel,
will post some pics once getting started but a pic of engine Normally asperated attached also so can see where it starts from,
ps this engine will be for sale soon as is spare with the complete exhaust system good runner no probs,
thanks all for now
sean
INDY BIRD
| posted on 25/5/09 at 08:42 PM |
standard ZX10r engine
INDY BIRD
| posted on 25/5/09 at 09:32 PM |
pics of zx10r pistons
u can see some damage on 1 piston from the valve
[Edited on 25/5/09 by INDY BIRD]
INDY BIRD
| posted on 26/5/09 at 08:51 PM |
update
well after 2 hours work tonight the engine is out,
now for the good stuff starting fitting in the new engine and turbo kit,
just need to work out best location for the intercooler
thats all for now pic attached
dean100yz
| posted on 27/5/09 at 01:47 PM |
Im lovin all these turbo posts recent. It must be bonkers power!
I thought it wasnt worth it as mines an old 918 blade only to read on another post a turbo being done with EFI
Be interested to see where you fit the 'cooler - cant see there being many places with it still running efficient
I think once i get mine back at the end of this year I may go down the same route
hobbsy
| posted on 27/5/09 at 02:45 PM |
What turbo are you going to run on this out of interest?
250 at wheels at 6psi is rather fruity
INDY BIRD
| posted on 28/5/09 at 10:26 PM |
Hi All
its a gt28 in a modified housing that velocity turbos do,
plenty of room for the intercooler i have a modified cosworth 4x4 intercooler to fit under the nose cone should be more than efficient,
as several friends are running them on dax turbo cars with other side of 350+ bhp busa and zzr1400 turbos with no issues,
was mocking up the intercooler tonight so will post some other [ics over the weekend,
Cheers all
sean
oh and i have got to also do the diff to a 3;14 as the 338 will run out of steam way to early
INDY BIRD
| posted on 30/5/09 at 07:57 PM |
Hi All again
a pic of the turbo and manifold waiting to be fitted,
mmm i love these things
INDY BIRD
| posted on 2/6/09 at 07:56 PM |
Hi Quick update,
Trnasfered all the goodies from the standard engine to the new engine today and fiited the turbo
MMMMMM im liking it another 2 ful days at it and it should all be complete,
just damm work gets in the way so wont get to it till after weekend now,
i cant wait to here it
cheers all
pic of new engine now attached just the plenum to do next
