Author: Subject: FS 4m 8mm copper tube - Sold to stevegough
r1_pete
posted on 27/5/09 at 11:57 AM Reply With Quote
I havent unrolled it to measure, but there are 4 and a quarter coils, 330mm diameter, so I make that a good 4m.
£10 - posted
[Edited on 28/5/09 by r1_pete] Rescued attachment BILD0165.JPG
hellbent345
posted on 27/5/09 at 01:47 PM Reply With Quote
could this be used for fuel lines for injection?
Thanks Al
cd.thomson
posted on 27/5/09 at 02:19 PM Reply With Quote
Yes Al, its what I'm using.
Craig
stevegough
posted on 28/5/09 at 08:36 AM Reply With Quote
u2u sent.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Ferg
posted on 28/5/09 at 09:45 AM Reply With Quote
Are you sure SVA allow Table W Copper for fuel lines??
I was under the impression they wanted Kunifer to avoid vibrational work hardening....
cd.thomson
posted on 28/5/09 at 10:54 AM Reply With Quote
Although a risk, I don't believe anybody on this forum or at Dax has had an issue with copper lines. At VOSA they judge the lines to be fuel proof and do not require any certification as far as I am aware. Using rubber p-clips and considering the mileage these cars do, I wouldnt be surprised if the copper lasted the lifetime of the car.
So in short, nothing to worry about as far as VOSA, and IMO builders, are concerned.
Craig
Ferg
posted on 28/5/09 at 07:19 PM Reply With Quote
I recall someone either on here or Pistonheads who got an SVA fail with 8mm copper fuel pipe.
The reason I remember this is because it's exactly what's on my son's Velocity in the garage and I was intending to replace it before he goes for test (in about 30 years )
