RJK350
| posted on 8/6/09 at 08:18 PM |
BEC, Cat Position
Where should the cat be fitted?
I have an Aprilia Tuono engine going in an MK. Can a cat be fitted under the bonnet or should it be fitted before the silencer.
Some bike silencers have the cat in the silencer.
Also any suggestions on a company to make an exhaust system in the Bristol area?
I'm open to any suggestions, thanks
daniel mason
| posted on 8/6/09 at 08:20 PM |
is it just for sva/iva ? or is it going to be a permanent fixture
RJK350
| posted on 8/6/09 at 08:22 PM |
I like to take it out after sva/iva
daniel mason
| posted on 8/6/09 at 08:32 PM |
most people seem to! someone on here will probably lend you a cat and silencer for sva/iva as standard silencer will probably not pass noise test.
then after test the nice loud exhaust can be put back on.people on here are very helpful
Richard Quinn
| posted on 8/6/09 at 08:56 PM |
If you are bringing both exhausts together before they exit the engine bay then you'll struggle to fit a cat in the engine bay. Mine was part
way up the pipe before the can (still is actually!)
LBMEFM
| posted on 8/6/09 at 09:14 PM |
Call MK in the morning they have silencers with internal cats that they hire. Barry
[Edited on 8/6/09 by LBMEFM]
Richard Quinn
| posted on 8/6/09 at 09:32 PM |
You will need a decent cat to get the Aprilia through emissions. Mine was a 200cpi sports cat and I struggled a bit. It had to be really, really hot
and was still a bit touch & go
