kendo
posted on 15/6/09 at 09:28 AM |
DHLA Tuning
A question for the dellorto experts out there. My engine (1600 xflow on twin 40 dhla's) is running way too lean at idle. As a result is
spitting back and very hot. The mix screws are wound all the way out but still too lean. The idle jets are .58 so I can only go up one more step to
.60's. My question is, is that likely to be enough?
I should add the timing looks good.
cheers
Steve G
posted on 15/6/09 at 09:44 AM |
How long is a piece of string.......
You'll only really know using a gas analyser to be honest.
dhutch
posted on 15/6/09 at 10:54 AM |
How would that work. Go down to the MOT man and get him to run it thought and give you a print out?
posted on 15/6/09 at 11:22 AM |
how is carbed fixed to manifold?
no chance of a carb-manifold air leak?
kendo
posted on 15/6/09 at 11:49 AM |
The carbs ar mounted using proper seals and the rubber compression washers all set at the right gaps. I don't think I've got an air leak.
That said it is not something I've expressly checked for.
Steve G
posted on 15/6/09 at 12:27 PM |
Well that would be better than guessing based on internet forum tuning. A colourtune would get it approximated but the only way to get it spot on is
to set it up properly with a gas tester. Rolling road session is always best in my book.
As mentioned though - worth checking for an air leak on the manifold first
PaulBuz
posted on 15/6/09 at 03:34 PM |
Hi
1st question, which dhla's?
If they are emmision specials, they are jetted totally different from normal dhla's.
Whats the letter after the DHLA bit?
Paul
kendo
posted on 16/6/09 at 08:30 AM |
they are dhlA 40h
PaulBuz
posted on 16/6/09 at 04:37 PM |
Yep. they are emmission carbs.
This is the place to ask about them.
http://www.sideways-technologies.co.uk/forum/Blah.pl?b-Del1/
Paul
posted on 16/6/09 at 05:11 PM |
That's a great forum, thanks for the link!
