Author: Subject: how far does an R1 clutch lever arm move?
james h
posted on 19/6/09 at 06:45 PM Reply With Quote
As above, I am trying to work out if the clutch travel is right.
By clutch lever arm I mean the one coming from the clutch cover. Engine is a 2000 5JJ R1.
Currently its maybe 50-60 degrees or so.
The pedal feels initially heavy then much lighter near end of the pedal travel. Is this the norm for a BEC clutch?
James
r1_pete
posted on 19/6/09 at 07:15 PM Reply With Quote
Just been and had a measure on my bike 2001 5jj
With the clutch engaged (lever not pulled) the arm and cable are 80 degrees to one another.
Pull the clutch and the lever moves 30 degrees, so the cable and lever are at 120 degrees.
Lever is constant pressure and smooth all the travel.
Hope that helps
Pete.
[Edited on 19/6/09 by r1_pete]
james h
posted on 19/6/09 at 07:35 PM Reply With Quote
Hope that helps
Pete.
Brilliant, thanks!
I have setup my clutch cable differently to how it is on a bike, I have made a bracket to go on the closest engine mount, so in effect the cable pull is 270 degrees to the original route (towards the front of the bike).
Seems that I get a bit more lever travel and it goes light towards the end of the travel - is it possible to pull the clutch too far and damage anything?
Thanks,
James
MkII
posted on 19/6/09 at 07:52 PM Reply With Quote
dont know about bikes but to much travel can damage a car clutch.
m.
james h
posted on 19/6/09 at 08:13 PM Reply With Quote
I think I am going to try an adjustable pedal stop. I suppose I will only find out once I get it off the axle stands!
yorkshire-engines
posted on 19/6/09 at 08:47 PM Reply With Quote
James there is a arrow and spot marks on the cover and lever when the free play is taken up on lever by hand these 2 should line up then the movement after that is about 30 degrees
cheer s malc
james h
posted on 19/6/09 at 09:16 PM Reply With Quote
cheer s malc
I must definitely have too much travel then.
When I took the car to the SVA for the first time, the way I had put the clutch lever and pedal meant the examiner was just taking up the slack. oops...
James
