Chris7
| posted on 10/3/04 at 09:29 AM |
ZX-9R Speedo
Hi
Has anyone got a ZX-9R Speedo working using the standard clocks that is relatively acurate if so how can i do it .
Mk-Ninja
| posted on 10/3/04 at 09:51 AM |
Im sure that MK9R is using standard clocks, have a look on him website.
I'm sure I've got one, just don't know where I've put it
MK9R
| posted on 10/3/04 at 10:40 AM |
Not actually got them working yet, but this is how i intend doing it (i'm actually half way through making the mounting bracket at the moment). I
am using the sensor from the original bike, that is mounted in the casting which covers the sprocket. The casting is obviously not being used, so i am
mounting the sensor from a bracket which bolts onto the engine mount, the sensor will pick up 3 lugs which have been equally spaced around the
sprocket/prop adaptor.
Here is a picture/sketch (sorry about the quality), i will try and get a better picture tonight when i have finished the bracket.
  sprocket
[Edited on 10/3/04 by MK9R]
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
MK9R
| posted on 10/3/04 at 10:43 AM |
Meant to say that i am using 3 lugs rather than 4 (on the bike) to reduce the error. I did a calculation on what the error would be and posted it on a
previous thread. I'll see if i can find it.
Cheers Austen
RGB car number 9
www.trackace.co.uk
MK9R
| posted on 10/3/04 at 10:44 AM |
Here it is:-
calculation thread
Cheers Austen
RGB car number 9
www.trackace.co.uk
Chris7
| posted on 11/3/04 at 08:03 AM |
Metal lug spacing
Hi dude
whats the distance for the metal lugs around the prop adaptor .
Thanks Chris B
MK9R
| posted on 11/3/04 at 08:05 AM |
equal spacing, 120 degs between them
Cheers Austen
RGB car number 9
www.trackace.co.uk
Chris7
| posted on 11/3/04 at 08:17 AM |
Bracket
willl make bracket up and see if it works
Thanks Chris B
