Author: Subject: Fitting Oil Pressure Gauge 2003 R1
spdpug98
posted on 1/7/09 at 07:42 PM Reply With Quote
Now that I have got the SVA out of the way, I am getting underway with my post SVA changes
As the R1 has no oil pressure warning/guage I am looking at fitting one, is there an easy way to fit one or is it major work
I have a spare Racetech oil pressure/water temperature gauge from my old race car sitting on the shelf so would like to use that
My Blog: http://spdpug98.wordpress.com/
adithorp
posted on 1/7/09 at 07:46 PM Reply With Quote
There's a plug in either end of the block oil gallery. Thats where Yamaha check the presure. You just need an adapter to screw in whichever end is most convienient for you. Do a search for the thread size; Durite make adapters that fit
Alternativly you can drill and tap the oit cooler bolt.
adrian
http://jpsc.org.uk/forum/
twybrow
posted on 1/7/09 at 07:47 PM Reply With Quote
Google Ahoy! http://www.fluke-motorsport.co.uk/technical/howto/200410_r1oilpressure/index.html
spdpug98
posted on 1/7/09 at 07:49 PM Reply With Quote
Thanks, super fast replies as usual, possibly should of Google'd but LCB is much better and faster and I didn't think!!!!
[Edited on 1/7/09 by spdpug98]
adithorp
posted on 1/7/09 at 07:57 PM Reply With Quote
Gallery plug is M16x1.5. Durite kit is Part No 0-523-98. Its a set of 3 (1/8th NPTF to M14, M16, M18.)
adrian
spdpug98
posted on 1/7/09 at 08:00 PM Reply With Quote
adrian
Thanks!
Wheels244
posted on 1/7/09 at 08:05 PM Reply With Quote
Dave
I drilled and tapped the oil cooler bolt and used a Racetech Oil Pressure Gauge.
Let me know if you want pics
Rob
spdpug98
posted on 1/7/09 at 08:09 PM Reply With Quote
Rob
That would be great.
Got my DVLA inspection next Wednesday so could be on the road by the following Monday
Dave
bassett
posted on 1/7/09 at 09:10 PM Reply With Quote
Hi Dave, good to hear the sva is out the way. i also went for the oil cooler bolt. it was a bit tricky to tap to 1/8npt but tightens up very snuggly and reads perfect with an electic gauge. I think you need one that measures upto 10bar.
[Edited on 1/7/09 by bassett]
adithorp
posted on 1/7/09 at 09:24 PM Reply With Quote
Originally posted by spdpug98
Rob
Dave
PMSL
speed8
posted on 2/7/09 at 01:11 AM Reply With Quote
I used a sandwich plate from thinkauto to go between the block and the filter. It has two fitting ports for temperature and pressure if you want both.
richardh
posted on 2/7/09 at 08:01 AM Reply With Quote
sandwich plate, sounds too easy!
Time for a change!
Kriss
posted on 2/7/09 at 12:23 PM Reply With Quote
basset - fancy doing mine mate?
afj
posted on 2/7/09 at 07:10 PM Reply With Quote
sorry to hijack but if you used the block plug to measure oil temp rather than pressure would the sender be reading just oil temp or be influenced by the block temp? or is it all the same
eerrrrrrrrrrrrrrrr
Major Stare
posted on 2/7/09 at 09:34 PM Reply With Quote
Drilled and tapped the oil coiler, works a treat with the DigDash
Jon "FISH"
