flak monkey
posted on 27/7/09 at 04:59 PM |
Kit Car Services - up and running
I am now in a position to offer a few useful services to fellow kitcar builders and others.
My website is http://kitcarservices.co.uk which outlines most of what I can offer.
These basically include:
Turning (up to 19" diameter) - this could be anything from suspension spacers to custom hubs.
Electrical and electronics work
Donor part reconditioning (including type 9 rebuilds at competitive prices)
Throttle body respacing (including fuel rails)
and all sorts of other things.
Prices will be given on a job by job basis.
Sera
http://www.motosera.com
posted on 27/7/09 at 05:00 PM |
good luck david!
flak monkey
posted on 27/7/09 at 05:01 PM |
Some examples of turning:
* Blanking plugs for throttle bodies
* Bushes made to your requirements (aluminium, brass, nylon, bronze etc)
* Spacers (for suspension, rose joints etc)
* Propshaft spacers - made to your requirements. Properly bossed and recessed to ensure concentricty
* Hubcentric wheel spacers made to your specification
* Camber adjusters to your sizes (for front or rear custom wishbones)
* Threaded tubes for wishbones - with your choice of thread including M18x1.5 for transit track rods)
* Custom aluminium gearknobs
* Indicator stalks
* Custom made aluminium fuel rails, aluminium extrusion, drilled to your requirements for injectors, end tapped 3/8BSPT, ready to fit brackets
* Sierra upright tapered adaptors eccentric or concentric, your choice
* Concentric clutch cylinder spacers to your requirements drilled to suit your application
* Custom alternator pulleys single vee and poly vee
* Custom water pump pulleys as above
* Trigger wheel fitting pinto and crossflow including trigger wheel – laser cut trigger wheels and pulley modified to fit your application. Trigger
wheel fitted on turned disc to ensure concentricity
* One off hose joiners
* Custom hubs
* Thread cutting available, both metric and imperial
Sera
eznfrank
Good luck with it mate!!
omega0684
posted on 27/7/09 at 05:10 PM |
your website keeps mentioning 'our services'. so who is your partner in crime dave?
you also have a typo in your 'about me ' section it should read
.....Formula Student projects for several years'
you missed of the 's' in years, lol
Good luck with the new venture Dave
[Edited on 27/7/09 by omega0684]
big_wasa
posted on 27/7/09 at 05:13 PM |
I will be in touch with a job then ![](/images//smilies/bigsmile.gif)
speedyxjs
posted on 27/7/09 at 05:20 PM |
Have bookmarked your site David. Will probably need to use your services in the future
Paradoxia0
posted on 27/7/09 at 06:06 PM |
Best of luck mate! I will point anyone our way who needs a service you can offer!
One comment on the website - you might want to make the picture in the top left corner a tad smaller... 268kb for an icon that size explains why it
took so long to load the pic!
Mark
There is no replacement for displacement...
york-rhino
posted on 27/7/09 at 07:59 PM |
Goodluck i have bookmarked your site.
locoboy
posted on 27/7/09 at 08:08 PM |
hi David can you do Sierra rack extensions?
Not bothered about the material as long as its fit for purpose. steel or ally i guess?
Im after a price on a pair.
thanks
BTW the site is really slow to load up the different pages.
[Edited on 27/7/09 by locoboy]
Locoboy
flak monkey
posted on 27/7/09 at 08:18 PM |
thanks
I can do rack extensions yes, see U2U.
Sites being slow as its getting a lot of hits at the moment. Otherwise its generally ok
Sera
Confused but excited.
posted on 28/7/09 at 11:15 PM |
Nice one David.
I wish you all the luck in the world.
May even U2U you in the future for a fuel rail, when I get that far.
imp paul
posted on 29/7/09 at 09:25 AM |
good luck Dave hope all goes very well for you .also nice to know some 1 on here can help with this type of stuff all the best Paul ![](/images//smilies/smile.gif)
flak monkey
posted on 29/7/09 at 04:09 PM |
Thank you for the support gents.
I thought I would post some pictures of a selection of the bits I have made as examples:
Duratec billet fuel rail
![](/galpreviews/m_P1000773.jpg) ![Duratec billet fuel rail](/gallery/m_P1000773.jpg) Duratec billet fuel rail
Simple ali spacer
![](/galpreviews/m_P1000774.jpg) ![Aluminium spacer](/gallery/m_P1000774.jpg) Aluminium spacer
Type 9 cable speedo blanking plugs
![](/galpreviews/m_P1000814.jpg) ![Type 9 speedo blanking plugs](/gallery/m_P1000814.jpg) Type 9 speedo blanking plugs
GSXR Injector blanking plugs
![](/galpreviews/m_P1000815.jpg) ![GSXR injector blanking plugs](/gallery/m_P1000815.jpg) GSXR injector blanking plugs
And the above fitted
![](/galpreviews/m_P1000816.jpg) ![GSXR injector blanking plugs](/gallery/m_P1000816.jpg) GSXR injector blanking plugs
Throttle body adpators
![](/galpreviews/m_P1000208.jpg) ![TB Adaptor](/gallery/m_P1000208.jpg) TB Adaptor
Sera
