Author: Subject: Blade & Diff combo max speeds ?
gixermark
posted on 9/9/09 at 03:47 PM Reply With Quote
Hi Guys,
i'm sure this exists somewhere on the forum.. but for the 919cc blade, does anyone have the max speeds with the various ford diffs - for live and independant diffs ?? i.e mainly 3.54 in live and 3.38 and 3.68 in independant ??
Thanks...........
progers
posted on 9/9/09 at 06:03 PM Reply With Quote
Depends what wheel/tyre combo you are running :-)
- Paul
progers
posted on 9/9/09 at 06:16 PM Reply With Quote
Seeing that I am such a nice chap and you have made the effort to come all the way to Snetterton, I've worked these out for you
Diff.....206/60/13.....185/60/13
3.62.....122...........117...(IRS)
3.54.....125...........120....(live axle)
3.38.....131...........125.5...(IRS)
All the speeds assume max of 11,500 revs, in reality you can squeeze a bit more out of the blade, but you are well past the max power point by then (around 10,750 I think).
Most racers just stick with the 3.38 or 3.54. Its not worth the bother to change diff for the shorter tracks.
Paul
[Edited on 9/9/09 by progers]
mark chandler
posted on 9/9/09 at 08:09 PM Reply With Quote
My standard blade engine with 3.62 LSD, 185/60/13's would pull 12,500 in top ~125 mph so perfect in this guise for the track.
Annoying on the road, really needs a 3.38 or lower as you can easily pull away in second.
Regards Mark
gixermark
posted on 10/9/09 at 09:15 AM Reply With Quote
your a star Paul... look forward to seeing the batmobile next week :-)
TimC
posted on 11/9/09 at 10:25 AM Reply With Quote
Use the force:
Gear Calculator Link from Chris Gamlin
