Author: Subject: GSXR1100 clutch
phelpsa
posted on 30/3/04 at 04:58 PM Reply With Quote
GSXR1100 clutch
The clutch release cylinder on my gixer 1100 engine is very close to the output shaft, meaning that if I were to put a propshaft adaptor on I would not be able to put the clutch release cylinder back on. Does anyone know if you can get a propshaft adaptor that is 4" or less in diameter as this would solve the problem?
Adam
jimgiblett
posted on 31/3/04 at 09:23 AM Reply With Quote
I thought most prop adaptors were <4"
My Stuart Taylor one is 87.5mm max o/d, 61.5mm min o/d on the spline.
posted on 31/3/04 at 09:40 AM Reply With Quote
Ours look very much like that and I believe is 90mm diameter.
phelpsa
posted on 31/3/04 at 09:56 AM Reply With Quote
Thanks, they are smaller than the diff flange then, as that measures 4 1/2". You have filled me with confidence again. Was looking at changing the engine for a ZZ-R1100 engine, but now i think I will stick with it, for the time being.
Adam
P.S What is the diameter of the propshaft at the adptor end. The Actual Propshat and thr flange.
[Edited on 31/3/04 by phelpsa]
jimgiblett
posted on 31/3/04 at 09:59 AM Reply With Quote
As you can seen in my pic above my bailey morris UJ flange is 87.5mm / 3.5" same size as the prop adaptor.
Are you making your own prop?
[Edited on 31/3/04 by jimgiblett]
phelpsa
posted on 31/3/04 at 10:02 AM Reply With Quote
No I am probably not making my own. I will probably buy one from Stuart Taylor or MK.
adam
posted on 31/3/04 at 10:05 AM Reply With Quote
Our flange too is almost the same... not too clear but you can see it!
Hope this helps!
