Author: Subject: from r1 to r1
antonio
posted on 6/10/09 at 10:19 AM Reply With Quote
from r1 to r1
hi there,
someone can tell me if mounting point are the same for a 2001 r1 engine and a 2005/2006 engine?
i have a good opportunity to get a 2005 engine, but don't want to cut my chassis to fit it (mnr vortx)
cheers!
ko_racer
posted on 6/10/09 at 10:43 AM Reply With Quote
No they are different. The engine is at a different angle too so exhaust won't fit either
lsdweb
posted on 6/10/09 at 11:39 AM Reply With Quote
As ko_racer says, they are different. Not by a lot but enough to need new mounts. Wiring and cooling will also need changing as well as the exhaust.
Don't ask how I know!
Wyn
progers
posted on 6/10/09 at 12:46 PM Reply With Quote
The first question is why would you want to do it anyway?
The R1 engine you have is only a few bhp less than the 2005 model (don't believe the exagerated manufactruer claims that use RAM air at 180mph) Upto 7-8K revs the older engine actually has better torque and power.
The 2004/5/6 engines are more difficult to get to run reliably as well, they tend to spit out oil from the crank breather at high revs (which can lead to oil starvation) and generally run hotter oil and water temps that can cause problems.
If you want to improve the driveability of the motor (some people have problems setting up the carbs) then a 2002/3 injected model will resolve that issue and will fit your existing mounts and exhaust set-up. Its only worth doing though if your old engine is knackered.
So bottom line is if you are doing this to gain better performance don't bother, it will be marginal and only be apparent when you are thrashing it at high revs. At the same time you may be introducing some gremlins into your BEC that you could do well without.
Food for thought
Paul
antonio
posted on 6/10/09 at 01:48 PM Reply With Quote
sorry guys, i ve made a mistake: my engine is not a 2001 (carbed vesion IICR) but a 2002-3 IE version.
maybe it's easier to go for a 2005-6 engine?
paul, thanks for your advice.i don't want to get more BHP, but my engine will need a rebuild within a year (race use only) and i 'll go for the SC route next year too, so i think it could be a good thing to upgrade a nearly new engine and fit it in my car rather than bolt my SC on a 8000+ miles engine...just my 2p opinion.
cheers
antonio
progers
posted on 6/10/09 at 08:46 PM Reply With Quote
Still won't be any easier, new mounts and exhaust will need altering. You will have a return line for the fuel though.....
Strapping a supercharger to the newer R1 will need a very well thought out install - for starters you will need to increase the cooling capacity (both water and oil) for the engine.
Have fun
- Paul
antonio
posted on 7/10/09 at 07:32 AM Reply With Quote
thanks paul, i'll think about it.
regards
antonio
