r1_manx
| posted on 23/10/09 at 02:54 PM |
Air filter for 2003 R1
Hey guys,
I am running an '03 Yamaha R1 engine in my mini and I am unable to run the standard airbox as it will foul the bonnet. Eventually I will get a
custom airbox made but for now I am looking for a sausage type filter to use on the engine. Can anyone on here please recommend a suitable filter and
where I can get one from? I would appreciate the help and any details of what other people are running on their R1 engines.
Ben
If im not in action, im in traction!
JoaoCaldeira
| posted on 23/10/09 at 03:08 PM |
Pipercross
afj
| posted on 23/10/09 at 03:18 PM |
are you able to turn the airbox around 180 degrees and fit it on backwards, thats what you do on a 7 type install
eerrrrrrrrrrrrrrrr
r1_manx
| posted on 23/10/09 at 03:30 PM |
No I had a look at flipping the air box round but is just so little space to work with in a mini engine bay. I'm just trying to find out if
anyone can supply a sausage type filter and backing plate for the 03 R1 engine or even individual sock filters for the throttle bodies? I had a look
on the pipercross website, but they only seem to list the performance filter which is a direct replacement for the filter within the standard air box.
afj
| posted on 23/10/09 at 03:44 PM |
ring tts in northamtonshire
eerrrrrrrrrrrrrrrr
hobbsy
| posted on 23/10/09 at 05:29 PM |
Or you can do a cut and shut on the standard one as I intend to do when I get around to it. (As long as you don't reduce the volume too
much).
I'd much rather chop that around a bit than my bonnet
Major Stare
| posted on 23/10/09 at 07:35 PM |
Had a TTS unit fitted to my 2003 R1.
Recomended !
Jon "FISH"
