Author: Subject: those with home made reverse
bigsteve
posted on 26/10/09 at 09:37 PM Reply With Quote
does anyone have any info or pictures of their home made reverses. i'm wanting to do one on my locost firebade and am not sure which way would be best. i can fabricate starter mountings no problem just need to know what is the best starter and sprocket etc. i have a cortina live back axle
cheers
steve
prawnabie
posted on 26/10/09 at 10:00 PM Reply With Quote
I think you will struggle to mount it near the diff, only place would be near the centre bearing or the motor itself.
Dangle_kt
posted on 26/10/09 at 10:31 PM Reply With Quote
As has been said you can't mount it at the back like most as the live axle moves, unlike the diff on a IRS car.
Ab performance said that it coul be fitted engine end, but it involves grinding the cases for clearence. Thankfully I passed sva prior to Iva so never had to bother.
MikeCapon
posted on 27/10/09 at 07:57 AM Reply With Quote
Apparently not impossible although its going to hike up the unsprung weight. Have a look here Link
andrew.carwithen
posted on 27/10/09 at 10:19 AM Reply With Quote
Mine is mounted adjacent to the engine. I bought it off ebay a few years back from a guy who had it fitted to a Stuart Taylor locoblade in the RGB series.
It essentially consists of a bike starter motor mounted on a spring-loaded sliding carriage, a ring gear sandwiched between the prop and adaptor and a cable operated lever (which also incorporates a momentary push-button) mounted in the transmission tunnel.
There is also a reduction gear between the starter's output shaft and offset pinion to reverse the direction of the starter.
To operate, I select neutral and then use the lever to pull the motor along it's sliding carriage so engaging the motor's pinion with the ring gear.
I then press the button in the top of the lever which completes a circuit via a remote mounted solenoid, so energising the starter and driving the car backwards.
The reverse is only suitable for a level surface as, due to it only being a bike starter and the car only having a bike battery, there isn't enough torque generated for any sort of incline.
Still, its enough to reverse me back onto my drive without having to get out of the car (which ws the main reason for fitting it.)
If I can't upload pics, there's a couple in my archive.
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=avon=electric=reverse.jpg
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=avon=electric= reverse.jpg2.jpg
[Edited on 27/10/09 by andrew.carwithen]
