Author: Subject: dyno jetting a fireblade
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
Building: Built MK Indy Blade, RH 2b Zetec, rebuilding locos
posted on 7/4/04 at 06:16 AM Reply With Quote
Ok folks, although my Indy isn;t yet on the road, constant haranguing from my mates has me thinking about getting a dynojet kit. from what i can gather, its a set o carb jets and a k&n filter. as im using the standard airbox etc, that shouldent be a prob- only thing that worries me is that it is not a bike exhaust system, and will therefore have different characteristics.
is it a good idea to do?? will it make any difference to power torque etc? will the engine run ok?? need rolling roaded???
as usual any suggestions, tips, ideas, slaggings etc all gratefully received!
Graham
phelpsa
posted on 7/4/04 at 07:42 AM Reply With Quote
You will probably need a rolling road session.
ChrisGamlin
posted on 7/4/04 at 10:20 AM Reply With Quote
If you are using the standard airbox then you may well get away without intalling one at all. As phelpsa says, it may still be worth running it up on a rolling road before you really give it some beans just in case the new exhaust makes it breath a bit better and so run a bit lean (could be nasty), but with the standard airbox you arent going to be a million miles out on jetting so spending £100 or so on a Dynojet kit probably isnt worthwhile.
Chris
posted on 7/4/04 at 11:19 AM Reply With Quote
OK. The fireblade engine we have installed had already been dyno-jetted and is running with the standard airbox and a K&N filter.
Chris, you say running a bit lean could be nasty. Why? Would it be wise to get a session on a rolling road and if so, where and how much do these cost.
Lastly, will we have problems with emissions at SVA?
As always, any advice would be appreciated
Digger Barnes
posted on 7/4/04 at 11:56 AM Reply With Quote
If you run an engine lean especially a bike engine that has high compression ratio's then you will get detonation (pinking). You will end up burning the exaust valves (I know Ive done it on a very high compression engine a few years ago) and in extreme cases it is possible to hole a piston!!!
200mph
posted on 7/4/04 at 12:00 PM Reply With Quote
leaning an engine out leads to detonation, and possible melted pistons and valve damage, plus you are also losing power.
rolling road sessions vary, with a power run about £35 ish, and a full setup can be £200, so I'm imagining the most yu'll need would be somewhere in between.
I wouldnt say its essential, but definately worthwhile
I would let you know where, but i dont know what county Rotherham is in, being a scot an all
Mark
[Edited on 7/4/04 by 9904169]
ChrisGamlin
posted on 7/4/04 at 12:39 PM Reply With Quote
Yup I agree with the others, running lean can cause piston / valve damage due to detonation. You'd probably feel it if it was running really lean (wouldnt rev out cleanly etc) but if its slightly less then it could seem to run OK but in the long term do some damage.
Chris
posted on 7/4/04 at 12:45 PM Reply With Quote
Thanks for the advice fellas. It will be worth getting it on a rolling road then at some point in the near future.
Doesn't it need to run lean to pass emissions test at SVA?
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
posted on 7/4/04 at 01:27 PM Reply With Quote
if the engine did run lean, are the carbs adjustable for mixture to counter it? (not very clued up on bike carbs!)
[Edited on 7/4/04 by scotlad]
mangogroove
posted on 7/4/04 at 02:04 PM Reply With Quote
scotlad We have one rolling road outfit next door to the saltmine up in Glenrothes. I will pop next door to see what they say.
Ill email you with the details prices ect.
regards pat
mangogroove
posted on 7/4/04 at 02:28 PM Reply With Quote
Rolling road chap does the power run for 50 quid (1 hour) but he doesnt do the jetting ect. He says to contact the legends boys (Robin Drysdale) at Knockhill to do the jetting. All the lads using the rolling road bring their tuners to do the adjustments.
www.starperformance.co.uk is the site
telephone 01592 770377
blackhead way Glenrothes
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
posted on 7/4/04 at 03:07 PM Reply With Quote
Thanks Pat i'll be up at knockhill soon, so i'll give em a shout
progers
posted on 7/4/04 at 05:16 PM Reply With Quote
Blade tuner
As I remember there is a chap called Dave Bloggs who is a sh*t hot bloke for jetting cards on bike engines. He lives somewhere in N Yorkshire and charges a couple of hours labour to do a set-up.
I don't know his contact details but one or two of the guys on the Yahoo BEC list know how to contact him
Hope that helps
- Paul
Alistair
posted on 7/4/04 at 05:50 PM Reply With Quote
His name is Dave Bogg. He's based between Bridlington and Malton.
Tel. 01944 738234
progers
posted on 7/4/04 at 05:58 PM Reply With Quote
Yep, thats the one!!
(I was close.....)
