aka Keith
| posted on 6/11/09 at 01:34 PM |
paddleshifts - again
Just thing of the winter mods, and contemplating a paddleshift system for the car.
I have most of the parts, but where can I get a collar that fits over the steering column from? Ie the bit that the actual paddle pivots around. - I
already have the paddles themeselves.
Ps I do not have access to fabrication facilities.
cheers
Craig
A1
| posted on 6/11/09 at 02:02 PM |
mk?
OX
| posted on 6/11/09 at 03:08 PM |
i used a triumph sprint st handle bar .remove the bar and your just left with the clamp , tap 2,8mm holes in it top and bottom for your rose joints
,, turn down the steering stem and the handle bar fits over it and clamps tight
[Edited on 6/11/09 by OX]
motorcycle_mayhem
| posted on 6/11/09 at 03:32 PM |
I have the complete collar that fits over a Sierra column, from the AB paddle kit. It's basically a tube, two slits to adjust, and two oilite
bushes TIG'd top and bottom taking M6 bolts to which the paddle set was simply bolted.
Unused, unabused. I fabricated my own for the much smaller Westfield column.
If this sounds like what you need, I'm happy to send a jpeg over to confirm.
aka Keith
| posted on 6/11/09 at 04:29 PM |
Motorcyle_mayem. U2U sent.
cheers
Craig
motorcycle_mayhem
| posted on 6/11/09 at 05:39 PM |
Good grief! There's a lot of people out there.... stop hassling me.
I've sent a jpeg over in response to aka, I'll happily send one elsewhere, but just hang on a while.....
