will642
| posted on 6/11/09 at 06:42 PM |
gear shift
can anyone help me with drawings or pics of a standardish gear shift arrangement or ideas as to how to fit one up.thanks in advance
jacko
| posted on 6/11/09 at 06:44 PM |
More info please
What gearbox type9/ bike engine/box
adithorp
| posted on 6/11/09 at 07:16 PM |
The clue is in the section.
http://jpsc.org.uk/forum/
jacko
| posted on 6/11/09 at 08:18 PM |
bodger
| posted on 6/11/09 at 10:53 PM |
Don't have any drawings but I've got to come up with a solution too in the near future. Noticed that a lot of the linkage kits supplied by
companies are using cable setups as opposed to rods because it's a bit easier on the gearbox. Spoke to Phil at MK the other day, they are moving
to a cable setup when they can find a new supplier.
Should be easy enough to fabricate one though. Gear lever to a bellcrank with two cables in a push/pull setup.
lsdweb
| posted on 6/11/09 at 11:49 PM |
Some photos of mine
here
and here
[Edited on 6/11/09 by lsdweb]
ReMan
| posted on 7/11/09 at 09:26 AM |
This may help too
http://www.locostbuilders.co.uk/viewthread.php?tid=35650
adithorp
| posted on 7/11/09 at 09:56 AM |
I made my own rod operated shift and fabricated paddle. I replaced the top casting/lock with a turned ally one. I had to lock out the adjustable
column reach adjustment with a plate, but the up/down is OK. Main thing is to make everything ridgid as any flex is magnified.
http://i189.photobucket.com/albums/z282/adrianthorp/Picture036-1.jpg
http://i189.photobucket.com/albums/z282/adrianthorp/Picture034.jpg
adrian
lsdweb
| posted on 7/11/09 at 10:15 AM |
I forgot to add that I needed to use a rod to get the gear shift sensor into the linkage - this would have been pretty difficult with a a push pull
cable.
