norfolkluego
posted on 30/12/09 at 12:20 PM |
Trigger wheel help needed
OK guys, I've got the crank pulley off (a 1.8 Zetec by the way) with your tip about jamming the flywheel, but....
the trigger wheel I've got is a solid one with just a central hole so it will have to fit flush against the forward face of the pulley, problem
is the pulley bolt is only 30mm long and the 'recess' in the pulley that it sat in is 25mm deep so I'd lose nearly all of the thred
depth. Do I
a. Just fit a longer bolt (are they M12, look like it)
or
b. Fit the trigger wheel behind th pulley so the existing bolt is OK
posted on 30/12/09 at 12:23 PM |
You will probably need to get a spacer turned up to fit between trigger wheel and pulley and then use a longer bolt.
If you want to fit it behind the pulley (is there room?) you will have to bore out the hole from the pulley hub to pass through and find some method
of locking it to the pulley.
norfolkluego
posted on 30/12/09 at 12:25 PM |
Scrap idea B, I've just trial fitted it and it would foul the belt on the water pump pulley (I think)
Is that an M12 bolt does anyone know?
[Edited on 30/12/09 by norfolkluego]
posted on 30/12/09 at 12:29 PM |
I'd use a spacer and a longer bolt. Just make sure you have some way of indexing the trigger wheel against the pulley otherwise if it turns at
all you've have infinitely variable timing (IVT) which is generally a bad thing
t16turbotone
posted on 30/12/09 at 12:30 PM |
why not fit long piece of threaded rod instead of crank bolt, and use three nuts...if you know what i mean??
ashg
posted on 30/12/09 at 12:51 PM |
i did it like this. sorry its a pinto but it may give you an idea
[Edited on 30/12/09 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
lsdweb
posted on 30/12/09 at 01:00 PM |
I'd peg it to the pulley then get centre machined out so that you can use the existing pulley bolt.
My old Zetec pulley
drury318
I might be missing something here but can`t you use the original set up on the flywheel & crank sensor?
norfolkluego
posted on 30/12/09 at 01:03 PM |
That's a cracking bit of work, don't have the gear to do that though
norfolkluego
posted on 30/12/09 at 01:08 PM |
CVH flywheel, no timing marks
Bigheppy
posted on 30/12/09 at 05:53 PM |
Slightly off this topic, I bought a 1.8cvh and it came with a front pulley that incorporates a trigger wheel. Dont know what the engine is out of.
Would this pulley fit a zetec crank ?
norfolkluego
posted on 30/12/09 at 06:14 PM |
Thanks for your help with this, I've gone with the 'mount wheel to pulley' option as I couldn't fin a bolt that would fit,
it's a wierd thing, looks like an M12 but it has an M10 thread.
Just need to move the timing mark onto the trigger wheel, after I've found the timing mark that is, all I can find is a mark from a blue felt
tip, wouldn't have thought that was Ford's standard way of doing it, anyone got a piccy of a Zetec pulley showing the mark(s)
ashg
posted on 30/12/09 at 07:17 PM |
i think as mentioned the cvh pully with the trigger wheel on it will fit the zetec.
